(401) Unauthorized response executing POST using HttpWebRequest
When I execute the following code with the requestendpoint variable set to "https://rms-world-check-one-api-pilot.thomsonreuters.com/v1/cases", I get a result.
When I change the requestendpoint variable to "https://rms-world-check-one-api-pilot.thomsonreuters.com/v1/cases/screeningRequest", I get a (401) Unauthorized error
My C# code is as follows:
DateTime dateValue = DateTime.UtcNow;
string date = DateTime.UtcNow.ToString("R");
string apikey = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx";
string apisecret = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx";
string gatewayurl = "/v1/";
string gatewayhost = "rms-world-check-one-api-pilot.thomsonreuters.com";
string requestendpoint = "https://rms-world-check-one-api-pilot.thomsonreuters.com/v1/cases/screeningRequest";
string postData = "{\"secondaryFields\":[],\"entityType\":\"INDIVIDUAL\",\"customFields\":[],\"groupId\":\"0a3687cf-6c70-198a-9b22-d3fa000009bb\",\"providerTypes\":[\"WATCHLIST\"],\"name\":\"john smith\"}";
UTF8Encoding encoding = new UTF8Encoding();
byte[] byte1 = encoding.GetBytes(postData);
string dataToSign = "(request-target): post " + gatewayurl + "cases\n" +
"host: " + gatewayhost + "\n" + // no https only the host name
"date: " + date + "\n" + // GMT date as a string
"content-type: " + "application/json" + "\n" +
"content-length: " + byte1.Length + "\n" +
postData;
string hmac = generateAuthHeader(dataToSign, apisecret);
string authorisation = "Signature keyId=\"" + apikey + "\",algorithm=\"hmac-sha256\",headers=\"(request-target) host date content-type content-length\",signature=\"" + hmac + "\"";
HttpWebRequest WebReq = (HttpWebRequest)WebRequest.Create(requestendpoint);
WebReq.Method = "POST";
WebReq.Headers.Add("Authorization", authorisation);
WebReq.Headers.Add("Cache-Control", "no-cache");
WebReq.ContentLength = postData.Length;
WebReq.Date = dateValue; // use datetime value GMT time
WebReq.ContentType = "application/json";
WebReq.ContentLength = byte1.Length;
Stream newStream = WebReq.GetRequestStream();
newStream.Write(byte1, 0, byte1.Length);
// Get the Response - Status OK
HttpWebResponse WebResp = (HttpWebResponse)WebReq.GetResponse();
// Status information about the request
Console.WriteLine(WebResp.StatusCode);
Console.WriteLine(WebResp.ResponseUri);
// Get the Response data
Stream Answer = WebResp.GetResponseStream();
StreamReader _Answer = new StreamReader(Answer);
string jsontxt = _Answer.ReadToEnd();
// convert json text to a pretty printout
var obj = Newtonsoft.Json.JsonConvert.DeserializeObject(jsontxt);
var f = Newtonsoft.Json.JsonConvert.SerializeObject(obj, Newtonsoft.Json.Formatting.Indented);
Console.WriteLine(f);
Console.WriteLine("Press any key");
Console.ReadKey(); // pause for any key
// Combine the data signature and the API secret key to get the HMAC
// This is the Microsoft HMACSHA256 code copied from the documentation
public static string generateAuthHeader(string dataToSign, string apisecret)
byte[] secretKey = Encoding.UTF8.GetBytes(apisecret);
HMACSHA256 hmac = new HMACSHA256(secretKey);
hmac.Initialize();
byte[] bytes = Encoding.UTF8.GetBytes(dataToSign);
byte[] rawHmac = hmac.ComputeHash(bytes);
string hex = BitConverter.ToString(rawHmac).Replace("-", "");
return (Convert.ToBase64String(rawHmac));
Any help will be appreciated
world-checkworld-check-oneerror
4.2k 7 5 6
@gerhardtm
Please keep the data to sign value as below and it should work:
string dataToSign = "(request-target): post " + gatewayurl + "cases/screeningRequest\n" +
postData
Kindly let me know if the solution helped you.
Thank you, that did the trick.
