Setting TickHistoryTimeAndSalesExtractionRequest.Condition.DateRangeTimeZone="UTC" has no effect on SFCJ0
I am requesting TickHistoryTimeAndSalesExtractionRequest for SFCJ0 for time range between 2020-04-01T00:00:00.000000000Z and 2020-04-01T23:59:59.999999999Z:
The data I receive starts at 2020-04-01T04:00:01.012562364Z and end at 2020-04-02T03:59:58.911651052Z, I would expect it to start at or after (near) 2020-04-01T00:00:00.000000000Z and end before (near) 2020-04-02T00:00:00.000000000Z, because I set DateRangeTimeZone = "UTC", ReportDateRangeType = ReportDateRangeType.Range, MessageTimeStampIn = TickHistoryTimeOptions.GmtUtc.
Am I doing anything wrong? I use the latest available version of RESTAPIToolkit for .NET.
var extractionRequest = new TickHistoryTimeAndSalesExtractionRequest
                    IdentifierList = new InstrumentIdentifierList
                        InstrumentIdentifiers = new[]
                                Identifier = "SFCJ0",
                                IdentifierType = IdentifierType.Ric
                        ValidationOptions = new InstrumentValidationOptions
                            AllowHistoricalInstruments = true
                        UseUserPreferencesForValidationOptions = false
                    Condition = new TickHistoryTimeAndSalesCondition
                        TimeRangeMode = TickHistoryTimeRangeMode.Inclusive,
                        QueryStartDate = DateTime.Parse("2020-04-01"),
                        QueryEndDate = DateTime.Parse("2020-04-01").AddDays(1).AddTicks(-1),
                        ApplyCorrectionsAndCancellations = false,
                        ExtractBy = TickHistoryExtractByMode.Ric,
                        MessageTimeStampIn = TickHistoryTimeOptions.GmtUtc,
                        SortBy = TickHistorySort.SingleByRic,
                        DisplaySourceRIC = false
                    ContentFieldNames = fields
tick-history-rest-api
11.3k 25 8 13
Hi @hrayr,
It could be due to the DateTime object you used for the QueryStartDate and QueryEndDate. The DateTime object somehow is converted using local timezone. The similar issue has been found here.
Please use DateTimeOffset instead.
QueryStartDate = new DateTimeOffset(2020, 4, 1, 0,0,0,System.TimeSpan.Zero),
QueryEndDate = new DateTimeOffset(2020, 4, 1, 23, 23, 59, System.TimeSpan.Zero),
23k 22 9 14
Hello @hrayr,
I have retested with TRTH C# .Net Example Application,
Replaced IBM.N with SFCJ0 midified fields
 ContentFieldNames = new[]
                    "Trade - Price",
                    "Trade - Volume",
                    "Trade - Exchange Tim
and extended printed data.
I see result data T01:00:00 - T21:14:39. This is consistent with result I get via Postmen, testing same request for SFCJ0.
MessageTimeStampIn in your request is same as in example. The difference must be elsewhere in code, as the result you describe differs.
I think example is easy to try on your side and should allow to see if you get the expected result on your side, then can copy into your custom request?
