Count of active subscribed items
As a ERT in Cloud client using Websocket, Is there a way to get the count of total subscribed items?
e.g. If my application has subscribed 10 RICs, is there a function call that I can get "10" as a result of my subscription?
refinitiv-realtimetreprdp-apiwebsocketsrrto
9.5k 10 5 7
Hello @otto.to.1
As far as I know, there is no any function like that. Your application needs to implement this by itself.
Thanks for the prompt reply!
11.5k 16 7 10
Hello @otto.to.1
Each stream the application open with the WebSocket API (connection, items subscriptions) has a unique "ID" attribute as a reference. It can also be used to match the request and responses.
You can check a number of subscription items from a number of "ID" reference (not a value of ID)
