ERT Cloud Web Update Frequency in WebSocket Api
Currently we try the implementation of
https://github.com/Refinitiv-API-Samples/Example.ERT.TypeScript.NodeJS.MarketPrice
we successfully connect to the websocket but there is something that bother me when i get the currency pair rate on January 15th 2020. we didn't receive rates between UTC ±00:30 up to ±10:10 . There is also no error. Is this a normal behaviour? And if some pair is only update 3 times a day is it also normal?
refinitiv-realtimetreprdp-apiwebsocketsrrtoforex
@arif
Can you share RICs that you are using?
the RIC we use is
'EUR=', 'JPY=', 'GBP=', 'AUD=', 'CHF=', 'NZD=','CAD=', 'IDR=', 'SAR=', 'THB=', 'VND=', 'MYR=', 'HKD=', 'CNY='
9.5k 10 5 7
Hello @arif
It is possible that you see some rates because data from ERT in cloud is conflated; the server does not send all ticks to the client. Hence, you will receive some rates.
