ValueError when retrieving timeseries
When I try to request timeseries via ek.get_timeseries a ValueError is thrown (only for specific stocks/parameters).
Example snippet with traceback:
>>> ek.get_timeseries(rics=['GHG.BH'], fields=['OPEN', 'CLOSE'], count=5)
Traceback (most recent call last):
  File "C:\Program Files (x86)\Python37-32\lib\site-packages\pandas\core\internals\managers.py", line 1677, in create_block_manager_from_blocks
    make_block(values=blocks[0], placement=slice(0, len(axes[0])))
  File "C:\Program Files (x86)\Python37-32\lib\site-packages\pandas\core\internals\blocks.py", line 3265, in make_block
    return klass(values, ndim=ndim, placement=placement)
  File "C:\Program Files (x86)\Python37-32\lib\site-packages\pandas\core\internals\blocks.py", line 128, in __init__
    "{mgr}".format(val=len(self.values), mgr=len(self.mgr_locs))
ValueError: Wrong number of items passed 1, placement implies 2
During handling of the above exception, another exception occurred:
  File "<stdin>", line 1, in <module>
  File "C:\Program Files (x86)\Python37-32\lib\site-packages\eikon\time_series.py", line 206, in get_timeseries
    data_frame = NiceDataFrame_Formatter(ts_result).get_data_frame()
  File "C:\Program Files (x86)\Python37-32\lib\site-packages\eikon\time_series.py", line 257, in get_data_frame
    data_frames, rics, fields = self._get_frame_list()
  File "C:\Program Files (x86)\Python37-32\lib\site-packages\eikon\time_series.py", line 290, in _get_frame_list
    df = pd.DataFrame(datapoints, columns=fields)
  File "C:\Program Files (x86)\Python37-32\lib\site-packages\pandas\core\frame.py", line 439, in __init__
    mgr = init_ndarray(data, index, columns, dtype=dtype, copy=copy)
  File "C:\Program Files (x86)\Python37-32\lib\site-packages\pandas\core\internals\construction.py", line 213, in init_ndarray
    return create_block_manager_from_blocks(block_values, [columns, index])
  File "C:\Program Files (x86)\Python37-32\lib\site-packages\pandas\core\internals\managers.py", line 1687, in create_block_manager_from_blocks
    construction_error(tot_items, blocks[0].shape[1:], axes, e)
  File "C:\Program Files (x86)\Python37-32\lib\site-packages\pandas\core\internals\managers.py", line 1716, in construction_error
    raise ValueError("Empty data passed with indices specified.")
ValueError: Empty data passed with indices specified.
It seems like the reason for the error is that there are no up-to-date quotes (latest GHG.BH quote is from 2019-11-04) and the number of returned rows is limited via the count param.
The ValueError is also thrown when data for multiple rics is requested, so one 'bad' ric that has no current quotes crashes the whole batch-query. I am pretty sure that this behaviour is not intended and that it should be fixed.
I've tested it on eikon version 1.0.1 and pre-release 1.1.2b0. If necessary I can provide additional examples (e.g. other rics that cause the same behaviour).
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonerror
18k 21 12 20
Hi @gabriel.g
Thanks for reporting this.
I can reproduce the same error.
I cannot confirm if this is an intended behavior but I will inform product manager to be aware of this issue.
In the case for this issue, solution is Eikon Python Dev released the fix server-side
Great, thank you!
As already mentioned it's mainly a problem when requesting quotes for a bunch of rics at once.
The ValueError gives no insight on which instrument caused the error, so I have to sequentially send a request for every single ric to find the culprit.
I'll probably write some kind of binary-search algorithm to circumvent it, but I'd still appreciate if you informed me on any news on this issue (e.g. by posting another reply into this thread).
