Is Eikon API down?
<module> df_chain1 = ek.get_data(chain_id, fields=field2, parameters={"SDate":date_end2, "EDate":date_start2, "Frq":"D"})
"C:\Program Files\Anaconda3\lib\site-packages\eikon\data_grid.py", line 141, in get_data result = eikon.json_requests.send_json_request(DataGrid_UDF_endpoint, payload, debug=debug) File "C:\Program Files\Anaconda3\lib\site-packages\eikon\json_requests.py", line 82, in send_json_request check_server_error(result) File "C:\Program Files\Anaconda3\lib\site-packages\eikon\json_requests.py", line 130, in check_server_error raise requests.HTTPError(error_message, response=server_response) requests.exceptions.HTTPError: Either datapoint 'DataGrid' doesn't exist or you do not have permission to execute this datapoint.
Hi I've been using Eikon API for quite a while.
Just a moment ago, I received this error. Is the API down?
Thanks.
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonerror
Oh, I have Same problem today!!
Same problem here...
Same problem here.
Seems like it is up&running again. What about you? @XxFaTexX @kengo_takahashi @Jan
Hey Tomas, likewise.
Looks like someone fixed it.
I would like to know why and if this issue would happen again.
Can someone from TR shed some light?
