Response: Backend error. 400 Bad Request
Dear Community,
so I recently started to play around with the Python Eikon Interface. Unfortunately for my latest code, I get a Backend error: 400 Bad Request - Honestly I don't know why. Funnily, it worked two days ago ...
My goal ist to split a list I have in even chunks of 1000 values per list and then get the data. Listdf is a flat list with RICS in the proper format. Thanks in advance.
chunksize = 1000
for i in range (0, len(listdf), chunksize):
    chunk = listdf[i:i+chunksize]
list2 =[]
    list2.append(ek.get_data(listdf[i:i+chunksize], ["TR.Revenue"]))
eikoneikon-data-apiworkspaceworkspace-data-apirefinitiv-dataplatform-eikonpythonerrorerror-400
If the request failed periodically, it could be timeout.
As I know, for the DataGrid service used by get_data, there is around 19 seconds' time-frame to execute the request. If it takes more than 19 seconds, it will return 400 Bad Request.
You may try to reduce the chucksize.
I am facing the same issue since 2 days for trying to fetch closePrice for single day only, for list of RIC's. After few request i get the famous 400 bad request.server error whereby i reduce the chucksize drastically (tried all from 1 to 500 chunksizes) but the request keeps failing with the same error? Is there any way to reproduce this at you end and some workaround this ?
