I try to download historical data for a stock (SHEN.OQ) using python Eikon API. It seems like there is no closing price print for this symbol on Feb 8th, 2006, which is confirmed when I check in Excel using the following formula:
=TR("SHEN.OQ","TR.PRICECLOSE","Frq=D SDate=2006-02-08 CH=Fd RH=IN;date")
(Output = NULL)
However, if I I use the below code in Python, it ignores this date and fills the data with the next days data. The final date is then set as NaN.
symbol = "SHEN.OQ" names_list = ["TR.PRICECLOSE", "TR.PRICECLOSE.DATE"] start_date = str(20060201) end_date = str(20060210) df, error = eikon.get_data(symbol, names_list, {"SDate": start_date, "EDate": end_date}, field_name=True) df
Find the output attached.
I assume this is a bug? Is there a workaround for this?
