Keep getting 401 in zero footprint synchronous screening api hit through postman
I am getting the response for SEQ-pre-groups: Get my top-level groups. Please find the screenshot below.
But I am getting error when I call the API SEQ-zfs-api-sync-screen-simple: Perform Zero Footprint Synchronous Screening: Simple. Please find the screenshot below.
Please advise on this issue.
world-checkworld-check-oneworld-check-one-zf
4.5k 4 7 8
@Kathirvel.Dhanavelu,
You can use the API call - 'SEQ-pre-group-case-template: Get the case template for a group' to fetch the skeleton of the group and this will also provide you the variable for the entityType and secondary fields to be used.
Hope this helps.
4.5k 4 7 8
Thank you for your query.
Could you please use the below URL format for the postman collection?
URL - { {protocol}}{ {zfs-gateway-host}}{ {zfs-gateway-url}}cases/screeningRequest
Please let us know if this helps.
I am using the Zero footprint screening API in postman. Now I am getting the response.
I need to filter the results of Zero footprint screening API by country. How to do it ?. There is no documentation for this on your developer portal.
Hello @Prabhjyot.Mandla
Could you please help the client with the follow-up question?
