ZFS API - Swagger code-gen Java : 403 X-Cache: Error from cloudfront
I just created my first ZFS API sample using java 8 with sources generated using swagger-codegen.
Following GET work with Postman :
{ {protocol}}{ {gateway-host}}{ {gateway-url}}reference/countries
With my java code i received this error :
INFOS: 1 * Client response received on thread main 1 < 403 1 < Connection: keep-alive 1 < Content-Length: 278 1 < Content-Type: application/json 1 < Date: Mon, 17 Jun 2019 11:49:06 GMT 1 < Via: 1.1 1437ff2cfbc1ea8c7a36e6b0ce6e935a.cloudfront.net (CloudFront) 1 < x-amz-apigw-id: bbCn0EYdDoEFWNg= 1 < X-Amz-Cf-Id: 1CH5M5jMA4gFDoN2ppJCYqKYTRQVel06t1fB5hSPQVB1Hiq-4dNxYg== 1 < x-amzn-ErrorType: IncompleteSignatureException 1 < x-amzn-RequestId: e8eddab7-90f5-11e9-a6a3-09a03b94e39f 1 < X-Cache: Error from cloudfront {"message":"'host' not a valid key=value pair (missing equal-sign) in Authorization header: 'Signature keyId=\"XXXXX\",algorithm=\"hmac-sha256\",headers=\"(request-target) host date\",signature=\"XXXX\"'."}
When i compare value of Authorization between Postman and Java it's the same.
Do i miss something else ?
world-checkworld-check-oneworld-check-one-zferror-403swagger
thank you again
@Prabhjyot.Mandla
This issue is solved man issue was under my data parameter :
DateFormat df = new SimpleDateFormat("EEE, dd MMM yyyy HH:mm:ss z");
Because My local is french by default under JVM i have to add :
DateFormat df = new SimpleDateFormat("EEE, dd MMM yyyy HH:mm:ss z", Locale.ENGLISH);
4.5k 4 7 8
@thomas.gauroy,
Thank you for your query.
Can you please provide us the full request headers and the response headers of the API call to look into it?
hi @Prabhjyot.Mandla
thank for your answer here the header content . :
Signature keyId="XXXXX",algorithm="hmac-sha256",headers="(request-target) host date",signature="n/Zj+fh8VH7wuUig7jW2xhyP56WnsSEpkMkG8Iqh2mg="
@thomas.gauroy
We would need the full request and response headers in order to investigate on the cause of the error.
/Library/Java/JavaVirtualMachines/jdk1.8.0_161.jdk/Contents/Home/bin/java -ea -Didea.test.cyclic.buffer.size=1048576 "-javaagent:/Applications/IntelliJ IDEA CE.app/Contents/lib/idea_rt.jar=56678:/Applications/IntelliJ IDEA CE.app/Contents/bin" -Dfile.encoding=UTF-8 -classpath "/Applications/IntelliJ IDEA CE.app/Contents/lib/idea_rt.jar:/Applications/IntelliJ IDEA CE.app/Contents/plugins/junit/lib/junit-rt.jar:/Applications/IntelliJ IDEA CE.app/Contents/plugins/junit/lib/junit5-rt.jar:/Library/Java/JavaVirtualMachines/jdk1.8.0_161.jdk/Contents/Home/jre/lib/charsets.jar:/Library/Java/JavaVirtualMachines/jdk1.8.0_161.jdk/Contents/Home/jre/lib/deploy.jar:/Library/Java/JavaVirtualMachines/jdk1.8.0_161.jdk/Contents/Home/jre/lib/ext/cldrdata.jar:/Library/Java/JavaVirtualMachines/jdk1.8.0_161.jdk/Contents/Home/jre/lib/ext/dnsns.jar:/Library/Java/JavaVirtualMachines/jdk1.8.0_161.jdk/Contents/Home/jre/lib/ext/jaccess.jar:/Library/Java/JavaVirtualMachines/jdk1.8.0_161.jdk/Contents/Home/jre/lib/ext/jfxrt.jar:/Library/Java/JavaVirtualMachines/jdk1.8.0_161.jdk/Contents/Home/jre/lib/ext/localedata.jar:/Library/Java/JavaVirtualMachines/jdk1.8.0_161.jdk/Contents/Home/jre/lib/ext/nashorn.jar:/Library/Java/JavaVirtualMachines/jdk1.8.0_161.jdk/Contents/Home/jre/lib/ext/sunec.jar:/Library/Java/JavaVirtualMachines/jdk1.8.0_161.jdk/Contents/Home/jre/lib/ext/sunjce_provider.jar:/Library/Java/JavaVirtualMachines/jdk1.8.0_161.jdk/Contents/Home/jre/lib/ext/sunpkcs11.jar:/Library/Java/JavaVirtualMachines/jdk1.8.0_161.jdk/Contents/Home/jre/lib/ext/zipfs.jar:/Library/Java/JavaVirtualMachines/jdk1.8.0_161.jdk/Contents/Home/jre/lib/javaws.jar:/Library/Java/JavaVirtualMachines/jdk1.8.0_161.jdk/Contents/Home/jre/lib/jce.jar:/Library/Java/JavaVirtualMachines/jdk1.8.0_161.jdk/Contents/Home/jre/lib/jfr.jar:/Library/Java/JavaVirtualMachines/jdk1.8.0_161.jdk/Contents/Home/jre/lib/jfxswt.jar:/Library/Java/JavaVirtualMachines/jdk1.8.0_161.jdk/Contents/Home/jre/lib/jsse.jar:/Library/Java/JavaVirtualMachines/jdk1.8.0_161.jdk/Contents/Home/jre/lib/management-agent.jar:/Library/Java/JavaVirtualMachines/jdk1.8.0_161.jdk/Contents/Home/jre/lib/plugin.jar:/Library/Java/JavaVirtualMachines/jdk1.8.0_161.jdk/Contents/Home/jre/lib/resources.jar:/Library/Java/JavaVirtualMachines/jdk1.8.0_161.jdk/Contents/Home/jre/lib/rt.jar:/Library/Java/JavaVirtualMachines/jdk1.8.0_161.jdk/Contents/Home/lib/ant-javafx.jar:/Library/Java/JavaVirtualMachines/jdk1.8.0_161.jdk/Contents/Home/lib/dt.jar:/Library/Java/JavaVirtualMachines/jdk1.8.0_161.jdk/Contents/Home/lib/javafx-mx.jar:/Library/Java/JavaVirtualMachines/jdk1.8.0_161.jdk/Contents/Home/lib/jconsole.jar:/Library/Java/JavaVirtualMachines/jdk1.8.0_161.jdk/Contents/Home/lib/packager.jar:/Library/Java/JavaVirtualMachines/jdk1.8.0_161.jdk/Contents/Home/lib/sa-jdi.jar:/Library/Java/JavaVirtualMachines/jdk1.8.0_161.jdk/Contents/Home/lib/tools.jar:/Users/thomasgauroy/Dev/KomgoProject/worldcheckproto/target/test-classes:/Users/thomasgauroy/Dev/KomgoProject/worldcheckproto/target/classes:/Users/thomasgauroy/.m2/repository/org/springframework/boot/spring-boot-starter-batch/2.1.4.RELEASE/spring-boot-starter-batch-2.1.4.RELEASE.jar:/Users/thomasgauroy/.m2/repository/org/springframework/boot/spring-boot-starter/2.1.4.RELEASE/spring-boot-starter-2.1.4.RELEASE.jar:/Users/thomasgauroy/.m2/repository/org/springframework/boot/spring-boot/2.1.4.RELEASE/spring-boot-2.1.4.RELEASE.jar:/Users/thomasgauroy/.m2/repository/org/springframework/boot/spring-boot-autoconfigure/2.1.4.RELEASE/spring-boot-autoconfigure-2.1.4.RELEASE.jar:/Users/thomasgauroy/.m2/repository/javax/annotation/javax.annotation-api/1.3.2/javax.annotation-api-1.3.2.jar:/Users/thomasgauroy/.m2/repository/org/springframework/spring-core/5.1.6.RELEASE/spring-core-5.1.6.RELEASE.jar:/Users/thomasgauroy/.m2/repository/org/springframework/spring-jcl/5.1.6.RELEASE/spring-jcl-5.1.6.RELEASE.jar:/Users/thomasgauroy/.m2/repository/org/yaml/snakeyaml/1.23/snakeyaml-1.23.jar:/Users/thomasgauroy/.m2/repository/org/springframework/boot/spring-boot-starter-jdbc/2.1.4.RELEASE/spring-boot-starter-jdbc-2.1.4.RELEASE.jar:/Users/thomasgauroy/.m2/repository/com/zaxxer/HikariCP/3.2.0/HikariCP-3.2.0.jar:/Users/thomasgauroy/.m2/repository/org/springframework/spring-jdbc/5.1.6.RELEASE/spring-jdbc-5.1.6.RELEASE.jar:/Users/thomasgauroy/.m2/repository/org/springframework/batch/spring-batch-core/4.1.2.RELEASE/spring-batch-core-4.1.2.RELEASE.jar:/Users/thomasgauroy/.m2/repository/javax/batch/javax.batch-api/1.0/javax.batch-api-1.0.jar:/Users/thomasgauroy/.m2/repository/org/codehaus/jettison/jettison/1.2/jettison-1.2.jar:/Users/thomasgauroy/.m2/repository/org/springframework/batch/spring-batch-infrastructure/4.1.2.RELEASE/spring-batch-infrastructure-4.1.2.RELEASE.jar:/Users/thomasgauroy/.m2/repository/org/springframework/retry/spring-retry/1.2.4.RELEASE/spring-retry-1.2.4.RELEASE.jar:/Users/thomasgauroy/.m2/repository/org/springframework/spring-aop/5.1.6.RELEASE/spring-aop-5.1.6.RELEASE.jar:/Users/thomasgauroy/.m2/repository/org/springframework/spring-beans/5.1.6.RELEASE/spring-beans-5.1.6.RELEASE.jar:/Users/thomasgauroy/.m2/repository/org/springframework/spring-context/5.1.6.RELEASE/spring-context-5.1.6.RELEASE.jar:/Users/thomasgauroy/.m2/repository/org/springframework/spring-expression/5.1.6.RELEASE/spring-expression-5.1.6.RELEASE.jar:/Users/thomasgauroy/.m2/repository/org/springframework/spring-tx/5.1.6.RELEASE/spring-tx-5.1.6.RELEASE.jar:/Users/thomasgauroy/.m2/repository/com/komgo/platform/samples/api/api-sample/1.0-SNAPSHOT/api-sample-1.0-SNAPSHOT.jar:/Users/thomasgauroy/.m2/repository/io/rest-assured/rest-assured/3.3.0/rest-assured-3.3.0.jar:/Users/thomasgauroy/.m2/repository/org/codehaus/groovy/groovy/2.4.15/groovy-2.4.15.jar:/Users/thomasgauroy/.m2/repository/org/codehaus/groovy/groovy-xml/2.4.15/groovy-xml-2.4.15.jar:/Users/thomasgauroy/.m2/repository/org/apache/httpcomponents/httpclient/4.5.3/httpclient-4.5.3.jar:/Users/thomasgauroy/.m2/repository/org/apache/httpcomponents/httpcore/4.4.6/httpcore-4.4.6.jar:/Users/thomasgauroy/.m2/repository/commons-codec/commons-codec/1.9/commons-codec-1.9.jar:/Users/thomasgauroy/.m2/repository/org/apache/httpcomponents/httpmime/4.5.3/httpmime-4.5.3.jar:/Users/thomasgauroy/.m2/repository/org/hamcrest/hamcrest-core/1.3/hamcrest-core-1.3.jar:/Users/thomasgauroy/.m2/repository/org/hamcrest/hamcrest-library/1.3/hamcrest-library-1.3.jar:/Users/thomasgauroy/.m2/repository/org/ccil/cowan/tagsoup/tagsoup/1.2.1/tagsoup-1.2.1.jar:/Users/thomasgauroy/.m2/repository/io/rest-assured/json-path/3.3.0/json-path-3.3.0.jar:/Users/thomasgauroy/.m2/repository/org/codehaus/groovy/groovy-json/2.4.15/groovy-json-2.4.15.jar:/Users/thomasgauroy/.m2/repository/io/rest-assured/rest-assured-common/3.3.0/rest-assured-common-3.3.0.jar:/Users/thomasgauroy/.m2/repository/io/rest-assured/xml-path/3.3.0/xml-path-3.3.0.jar:/Users/thomasgauroy/.m2/repository/org/apache/commons/commons-lang3/3.4/commons-lang3-3.4.jar:/Users/thomasgauroy/.m2/repository/javax/xml/bind/jaxb-api/2.2.12/jaxb-api-2.2.12.jar:/Users/thomasgauroy/.m2/repository/com/sun/xml/bind/jaxb-osgi/2.2.10/jaxb-osgi-2.2.10.jar:/Users/thomasgauroy/.m2/repository/org/apache/sling/org.apache.sling.javax.activation/0.1.0/org.apache.sling.javax.activation-0.1.0.jar:/Users/thomasgauroy/.m2/repository/javax/activation/activation/1.1.1/activation-1.1.1.jar:/Users/thomasgauroy/.m2/repository/javax/ws/rs/javax.ws.rs-api/2.1.1/javax.ws.rs-api-2.1.1.jar:/Users/thomasgauroy/.m2/repository/javax/json/javax.json-api/1.1.4/javax.json-api-1.1.4.jar:/Users/thomasgauroy/.m2/repository/org/mongodb/mongo-java-driver/3.9.1/mongo-java-driver-3.9.1.jar:/Users/thomasgauroy/.m2/repository/com/google/code/gson/gson/2.8.5/gson-2.8.5.jar:/Users/thomasgauroy/.m2/repository/org/threeten/threetenbp/1.3.8/threetenbp-1.3.8.jar:/Users/thomasgauroy/.m2/repository/com/squareup/okhttp3/okhttp/3.14.1/okhttp-3.14.1.jar:/Users/thomasgauroy/.m2/repository/com/squareup/okio/okio/1.17.2/okio-1.17.2.jar:/Users/thomasgauroy/.m2/repository/io/gsonfire/gson-fire/1.0.1/gson-fire-1.0.1.jar:/Users/thomasgauroy/.m2/repository/io/swagger/codegen/v3/swagger-codegen-maven-plugin/3.0.8/swagger-codegen-maven-plugin-3.0.8.jar:/Users/thomasgauroy/.m2/repository/org/apache/maven/maven-core/3.2.5/maven-core-3.2.5.jar:/Users/thomasgauroy/.m2/repository/org/apache/maven/maven-model/3.2.5/maven-model-3.2.5.jar:/Users/thomasgauroy/.m2/repository/org/apache/maven/maven-settings/3.2.5/maven-settings-3.2.5.jar:/Users/thomasgauroy/.m2/repository/org/apache/maven/maven-settings-builder/3.2.5/maven-settings-builder-3.2.5.jar:/Users/thomasgauroy/.m2/repository/org/apache/maven/maven-repository-metadata/3.2.5/maven-repository-metadata-3.2.5.jar:/Users/thomasgauroy/.m2/repository/org/apache/maven/maven-artifact/3.2.5/maven-artifact-3.2.5.jar:/Users/thomasgauroy/.m2/repository/org/apache/maven/maven-model-builder/3.2.5/maven-model-builder-3.2.5.jar:/Users/thomasgauroy/.m2/repository/org/apache/maven/maven-aether-provider/3.2.5/maven-aether-provider-3.2.5.jar:/Users/thomasgauroy/.m2/repository/org/eclipse/aether/aether-spi/1.0.0.v20140518/aether-spi-1.0.0.v20140518.jar:/Users/thomasgauroy/.m2/repository/org/eclipse/aether/aether-impl/1.0.0.v20140518/aether-impl-1.0.0.v20140518.jar:/Users/thomasgauroy/.m2/repository/org/eclipse/aether/aether-api/1.0.0.v20140518/aether-api-1.0.0.v20140518.jar:/Users/thomasgauroy/.m2/repository/org/eclipse/aether/aether-util/1.0.0.v20140518/aether-util-1.0.0.v20140518.jar:/Users/thomasgauroy/.m2/repository/org/eclipse/sisu/org.eclipse.sisu.plexus/0.3.0.M1/org.eclipse.sisu.plexus-0.3.0.M1.jar:/Users/thomasgauroy/.m2/repository/javax/enterprise/cdi-api/1.0/cdi-api-1.0.jar:/Users/thomasgauroy/.m2/repository/javax/annotation/jsr250-api/1.0/jsr250-api-1.0.jar:/Users/thomasgauroy/.m2/repository/org/eclipse/sisu/org.eclipse.sisu.inject/0.3.0.M1/org.eclipse.sisu.inject-0.3.0.M1.jar:/Users/thomasgauroy/.m2/repository/org/sonatype/sisu/sisu-guice/3.2.3/sisu-guice-3.2.3-no_aop.jar:/Users/thomasgauroy/.m2/repository/javax/inject/javax.inject/1/javax.inject-1.jar:/Users/thomasgauroy/.m2/repository/aopalliance/aopalliance/1.0/aopalliance-1.0.jar:/Users/thomasgauroy/.m2/repository/org/codehaus/plexus/plexus-interpolation/1.21/plexus-interpolation-1.21.jar:/Users/thomasgauroy/.m2/repository/org/codehaus/plexus/plexus-utils/3.0.20/plexus-utils-3.0.20.jar:/Users/thomasgauroy/.m2/repository/org/codehaus/plexus/plexus-classworlds/2.5.2/plexus-classworlds-2.5.2.jar:/Users/thomasgauroy/.m2/repository/org/codehaus/plexus/plexus-component-annotations/1.5.5/plexus-component-annotations-1.5.5.jar:/Users/thomasgauroy/.m2/repository/org/sonatype/plexus/plexus-sec-dispatcher/1.3/plexus-sec-dispatcher-1.3.jar:/Users/thomasgauroy/.m2/repository/org/sonatype/plexus/plexus-cipher/1.4/plexus-cipher-1.4.jar:/Users/thomasgauroy/.m2/repository/org/apache/maven/maven-compat/3.2.5/maven-compat-3.2.5.jar:/Users/thomasgauroy/.m2/repository/org/apache/maven/wagon/wagon-provider-api/2.8/wagon-provider-api-2.8.jar:/Users/thomasgauroy/.m2/repository/org/apache/maven/maven-plugin-api/3.2.5/maven-plugin-api-3.2.5.jar:/Users/thomasgauroy/.m2/repository/org/apache/maven/plugin-tools/maven-plugin-annotations/3.4/maven-plugin-annotations-3.4.jar:/Users/thomasgauroy/.m2/repository/io/swagger/codegen/v3/swagger-codegen/3.0.8/swagger-codegen-3.0.8.jar:/Users/thomasgauroy/.m2/repository/io/swagger/swagger-parser/1.0.44/swagger-parser-1.0.44.jar:/Users/thomasgauroy/.m2/repository/io/swagger/swagger-core/1.5.22/swagger-core-1.5.22.jar:/Users/thomasgauroy/.m2/repository/com/fasterxml/jackson/dataformat/jackson-dataformat-yaml/2.9.8/jackson-dataformat-yaml-2.9.8.jar:/Users/thomasgauroy/.m2/repository/io/swagger/swagger-models/1.5.22/swagger-models-1.5.22.jar:/Users/thomasgauroy/.m2/repository/io/swagger/swagger-annotations/1.5.22/swagger-annotations-1.5.22.jar:/Users/thomasgauroy/.m2/repository/javax/validation/validation-api/1.1.0.Final/validation-api-1.1.0.Final.jar:/Users/thomasgauroy/.m2/repository/io/swagger/parser/v3/swagger-parser/2.0.12/swagger-parser-2.0.12.jar:/Users/thomasgauroy/.m2/repository/io/swagger/parser/v3/swagger-parser-v2-converter/2.0.12/swagger-parser-v2-converter-2.0.12.jar:/Users/thomasgauroy/.m2/repository/io/swagger/core/v3/swagger-models/2.0.8/swagger-models-2.0.8.jar:/Users/thomasgauroy/.m2/repository/io/swagger/parser/v3/swagger-parser-core/2.0.12/swagger-parser-core-2.0.12.jar:/Users/thomasgauroy/.m2/repository/io/swagger/parser/v3/swagger-parser-v3/2.0.12/swagger-parser-v3-2.0.12.jar:/Users/thomasgauroy/.m2/repository/io/swagger/core/v3/swagger-core/2.0.8/swagger-core-2.0.8.jar:/Users/thomasgauroy/.m2/repository/io/swagger/core/v3/swagger-annotations/2.0.8/swagger-annotations-2.0.8.jar:/Users/thomasgauroy/.m2/repository/io/swagger/swagger-codegen/2.4.5/swagger-codegen-2.4.5.jar:/Users/thomasgauroy/.m2/repository/io/swagger/swagger-compat-spec-parser/1.0.44/swagger-compat-spec-parser-1.0.44.jar:/Users/thomasgauroy/.m2/repository/com/github/java-json-tools/json-schema-validator/2.2.8/json-schema-validator-2.2.8.jar:/Users/thomasgauroy/.m2/repository/com/github/java-json-tools/json-schema-core/1.2.8/json-schema-core-1.2.8.jar:/Users/thomasgauroy/.m2/repository/com/github/fge/uri-template/0.9/uri-template-0.9.jar:/Users/thomasgauroy/.m2/repository/javax/mail/mailapi/1.4.3/mailapi-1.4.3.jar:/Users/thomasgauroy/.m2/repository/joda-time/joda-time/2.9.7/joda-time-2.9.7.jar:/Users/thomasgauroy/.m2/repository/com/googlecode/libphonenumber/libphonenumber/8.0.0/libphonenumber-8.0.0.jar:/Users/thomasgauroy/.m2/repository/net/sf/jopt-simple/jopt-simple/5.0.3/jopt-simple-5.0.3.jar:/Users/thomasgauroy/.m2/repository/com/github/fge/json-patch/1.6/json-patch-1.6.jar:/Users/thomasgauroy/.m2/repository/com/github/fge/jackson-coreutils/1.6/jackson-coreutils-1.6.jar:/Users/thomasgauroy/.m2/repository/com/github/fge/msg-simple/1.1/msg-simple-1.1.jar:/Users/thomasgauroy/.m2/repository/com/github/fge/btf/1.2/btf-1.2.jar:/Users/thomasgauroy/.m2/repository/com/samskivert/jmustache/1.12/jmustache-1.12.jar:/Users/thomasgauroy/.m2/repository/org/slf4j/slf4j-ext/1.7.25/slf4j-ext-1.7.25.jar:/Users/thomasgauroy/.m2/repository/ch/qos/logback/logback-classic/1.2.3/logback-classic-1.2.3.jar:/Users/thomasgauroy/.m2/repository/ch/qos/logback/logback-core/1.2.3/logback-core-1.2.3.jar:/Users/thomasgauroy/.m2/repository/commons-cli/commons-cli/1.2/commons-cli-1.2.jar:/Users/thomasgauroy/.m2/repository/com/google/guava/guava/23.0/guava-23.0.jar:/Users/thomasgauroy/.m2/repository/com/google/code/findbugs/jsr305/1.3.9/jsr305-1.3.9.jar:/Users/thomasgauroy/.m2/repository/com/google/errorprone/error_prone_annotations/2.0.18/error_prone_annotations-2.0.18.jar:/Users/thomasgauroy/.m2/repository/com/google/j2objc/j2objc-annotations/1.1/j2objc-annotations-1.1.jar:/Users/thomasgauroy/.m2/repository/org/codehaus/mojo/animal-sniffer-annotations/1.14/animal-sniffer-annotations-1.14.jar:/Users/thomasgauroy/.m2/repository/com/github/jknack/handlebars/4.0.6/handlebars-4.0.6.jar:/Users/thomasgauroy/.m2/repository/org/antlr/antlr4-runtime/4.5.1-1/antlr4-runtime-4.5.1-1.jar:/Users/thomasgauroy/.m2/repository/org/mozilla/rhino/1.7R4/rhino-1.7R4.jar:/Users/thomasgauroy/.m2/repository/com/atlassian/commonmark/commonmark/0.9.0/commonmark-0.9.0.jar:/Users/thomasgauroy/.m2/repository/io/swagger/codegen/v3/swagger-codegen-generators/1.0.8/swagger-codegen-generators-1.0.8.jar:/Users/thomasgauroy/.m2/repository/com/itextpdf/itextpdf/5.5.13/itextpdf-5.5.13.jar:/Users/thomasgauroy/.m2/repository/io/socket/socket.io-client/1.0.0/socket.io-client-1.0.0.jar:/Users/thomasgauroy/.m2/repository/io/socket/engine.io-client/1.0.0/engine.io-client-1.0.0.jar:/Users/thomasgauroy/.m2/repository/org/json/json/20090211/json-20090211.jar:/Users/thomasgauroy/.m2/repository/org/glassfish/jersey/core/jersey-common/2.28/jersey-common-2.28.jar:/Users/thomasgauroy/.m2/repository/jakarta/ws/rs/jakarta.ws.rs-api/2.1.5/jakarta.ws.rs-api-2.1.5.jar:/Users/thomasgauroy/.m2/repository/jakarta/annotation/jakarta.annotation-api/1.3.4/jakarta.annotation-api-1.3.4.jar:/Users/thomasgauroy/.m2/repository/org/glassfish/hk2/external/jakarta.inject/2.5.0/jakarta.inject-2.5.0.jar:/Users/thomasgauroy/.m2/repository/org/glassfish/hk2/osgi-resource-locator/1.0.1/osgi-resource-locator-1.0.1.jar:/Users/thomasgauroy/.m2/repository/com/fasterxml/jackson/core/jackson-databind/2.9.9/jackson-databind-2.9.9.jar:/Users/thomasgauroy/.m2/repository/com/fasterxml/jackson/core/jackson-annotations/2.9.0/jackson-annotations-2.9.0.jar:/Users/thomasgauroy/.m2/repository/com/fasterxml/jackson/core/jackson-core/2.9.9/jackson-core-2.9.9.jar:/Users/thomasgauroy/.m2/repository/org/glassfish/jersey/core/jersey-client/2.28/jersey-client-2.28.jar:/Users/thomasgauroy/.m2/repository/org/glassfish/jersey/media/jersey-media-json-jackson/2.28/jersey-media-json-jackson-2.28.jar:/Users/thomasgauroy/.m2/repository/org/glassfish/jersey/ext/jersey-entity-filtering/2.28/jersey-entity-filtering-2.28.jar:/Users/thomasgauroy/.m2/repository/com/fasterxml/jackson/module/jackson-module-jaxb-annotations/2.9.8/jackson-module-jaxb-annotations-2.9.8.jar:/Users/thomasgauroy/.m2/repository/org/glassfish/jersey/media/jersey-media-multipart/2.28/jersey-media-multipart-2.28.jar:/Users/thomasgauroy/.m2/repository/org/jvnet/mimepull/mimepull/1.9.11/mimepull-1.9.11.jar:/Users/thomasgauroy/.m2/repository/com/github/joschi/jackson/jackson-datatype-threetenbp/2.6.4/jackson-datatype-threetenbp-2.6.4.jar:/Users/thomasgauroy/.m2/repository/com/brsanthu/migbase64/2.2/migbase64-2.2.jar:/Users/thomasgauroy/.m2/repository/org/glassfish/jersey/inject/jersey-hk2/2.28/jersey-hk2-2.28.jar:/Users/thomasgauroy/.m2/repository/org/glassfish/hk2/hk2-locator/2.5.0/hk2-locator-2.5.0.jar:/Users/thomasgauroy/.m2/repository/org/glassfish/hk2/external/aopalliance-repackaged/2.5.0/aopalliance-repackaged-2.5.0.jar:/Users/thomasgauroy/.m2/repository/org/glassfish/hk2/hk2-api/2.5.0/hk2-api-2.5.0.jar:/Users/thomasgauroy/.m2/repository/org/glassfish/hk2/hk2-utils/2.5.0/hk2-utils-2.5.0.jar:/Users/thomasgauroy/.m2/repository/org/javassist/javassist/3.22.0-CR2/javassist-3.22.0-CR2.jar:/Users/thomasgauroy/.m2/repository/org/apache/commons/commons-csv/1.4/commons-csv-1.4.jar:/Users/thomasgauroy/.m2/repository/junit/junit/4.0/junit-4.0.jar:/Users/thomasgauroy/.m2/repository/net/sourceforge/tess4j/tess4j/4.3.1/tess4j-4.3.1.jar:/Users/thomasgauroy/.m2/repository/net/java/dev/jna/jna/5.1.0/jna-5.1.0.jar:/Users/thomasgauroy/.m2/repository/com/github/jai-imageio/jai-imageio-core/1.4.0/jai-imageio-core-1.4.0.jar:/Users/thomasgauroy/.m2/repository/org/ghost4j/ghost4j/1.0.1/ghost4j-1.0.1.jar:/Users/thomasgauroy/.m2/repository/log4j/log4j/1.2.17/log4j-1.2.17.jar:/Users/thomasgauroy/.m2/repository/commons-beanutils/commons-beanutils/1.9.2/commons-beanutils-1.9.2.jar:/Users/thomasgauroy/.m2/repository/commons-collections/commons-collections/3.2.1/commons-collections-3.2.1.jar:/Users/thomasgauroy/.m2/repository/org/apache/xmlgraphics/xmlgraphics-commons/1.4/xmlgraphics-commons-1.4.jar:/Users/thomasgauroy/.m2/repository/com/lowagie/itext/2.1.7/itext-2.1.7.jar:/Users/thomasgauroy/.m2/repository/org/apache/pdfbox/pdfbox/2.0.12/pdfbox-2.0.12.jar:/Users/thomasgauroy/.m2/repository/org/apache/pdfbox/fontbox/2.0.12/fontbox-2.0.12.jar:/Users/thomasgauroy/.m2/repository/commons-logging/commons-logging/1.2/commons-logging-1.2.jar:/Users/thomasgauroy/.m2/repository/org/apache/pdfbox/pdfbox-tools/2.0.12/pdfbox-tools-2.0.12.jar:/Users/thomasgauroy/.m2/repository/org/apache/pdfbox/pdfbox-debugger/2.0.12/pdfbox-debugger-2.0.12.jar:/Users/thomasgauroy/.m2/repository/org/apache/pdfbox/jbig2-imageio/3.0.2/jbig2-imageio-3.0.2.jar:/Users/thomasgauroy/.m2/repository/commons-io/commons-io/2.6/commons-io-2.6.jar:/Users/thomasgauroy/.m2/repository/net/sourceforge/lept4j/lept4j/1.10.0/lept4j-1.10.0.jar:/Users/thomasgauroy/.m2/repository/org/jboss/jboss-vfs/3.2.14.Final/jboss-vfs-3.2.14.Final.jar:/Users/thomasgauroy/.m2/repository/org/jboss/logging/jboss-logging/3.1.4.GA/jboss-logging-3.1.4.GA.jar:/Users/thomasgauroy/.m2/repository/org/slf4j/jul-to-slf4j/1.7.25/jul-to-slf4j-1.7.25.jar:/Users/thomasgauroy/.m2/repository/org/slf4j/slf4j-api/1.7.25/slf4j-api-1.7.25.jar:/Users/thomasgauroy/.m2/repository/org/slf4j/jcl-over-slf4j/1.7.25/jcl-over-slf4j-1.7.25.jar" com.intellij.rt.execution.junit.JUnitStarter -ideVersion5 -junit4 TestLibs,getCountriesFromWorldCheck
      Signature keyId="XXXXX",algorithm="hmac-sha256",headers="(request-target) host date",signature="RmK/jmXarBP6yl3J6+Dpllo4tOW23oHNcQTE8gK7Ytk="
      (request-target): get /v1/reference/countries
      host: zfs-world-check-one-api-pilot.thomsonreuters.com
      date: mer., 19 juin 2019 12:44:32 GMT
      juin 19, 2019 2:44:33 PM org.glassfish.jersey.logging.LoggingInterceptor log
      INFOS: 1 * Sending client request on thread main
      1 > GET https://zfs-world-check-one-api-pilot.thomsonreuters.com/v1/reference/countries
      1 > Accept: application/json
      1 > Authorization: Signature keyId="XXXXX",algorithm="hmac-sha256",headers="(request-target) host date",signature="RmK/jmXarBP6yl3J6+Dpllo4tOW23oHNcQTE8gK7Ytk="
      1 > cache-control: no-cache
      1 > contentLength: 212
      1 > Date: mer., 19 juin 2019 12:44:32 GMT
      1 > Host: zfs-world-check-one-api-pilot.thomsonreuters.com
      1 > provider-type: WATCHLIST
      1 > User-Agent: Swagger-Codegen/1.0.0/java
      juin 19, 2019 2:44:33 PM org.glassfish.jersey.client.internal.HttpUrlConnector setOutboundHeaders
      AVERTISSEMENT: Attempt to send restricted header(s) while the [sun.net.http.allowRestrictedHeaders] system property not set. Header(s) will possibly be ignored.
      juin 19, 2019 2:44:34 PM org.glassfish.jersey.logging.LoggingInterceptor log
      1 < 403
      1 < Date: Wed, 19 Jun 2019 12:44:34 GMT
      1 < Via: 1.1 9946ab784d1328de1a34d3840ab6cea6.cloudfront.net (CloudFront)
      1 < x-amz-apigw-id: bhwn5EJjjoEFhYQ=
      1 < X-Amz-Cf-Id: 2ubEPv3h40PbMDuvPJtMJOSfoNUJKK0l0Gv6cxWzL8j1SdbtSbZqhA==
      1 < X-Amz-Cf-Pop: CDG3-C1
      1 < x-amzn-RequestId: fdb1891b-928f-11e9-bd35-4da1f726be6c
      {"message":"'host' not a valid key=value pair (missing equal-sign) in Authorization header: 'Signature keyId=\"XXXXX\",algorithm=\"hmac-sha256\",headers=\"(request-target) host date\",signature=\"RmK/jmXarBP6yl3J6+Dpllo4tOW23oHNcQTE8gK7Ytk=\"'."}
      com.komgo.io.swagger.api.proto.ApiException: {"message":"'host' not a valid key=value pair (missing equal-sign) in Authorization header: 'Signature keyId=\"XXXXX\",algorithm=\"hmac-sha256\",headers=\"(request-target) host date\",signature=\"RmK/jmXarBP6yl3J6+Dpllo4tOW23oHNcQTE8gK7Ytk=\"'."}
      at com.komgo.io.swagger.api.proto.ApiClient.invokeAPI(ApiClient.java:737)
      at com.komgo.io.swagger.api.proto.worldcheck.ReferenceApi.referenceCountriesGet(ReferenceApi.java:73)
      at TestLibs.getCountriesFromWorldCheck(TestLibs.java:101)
      at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
      at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
      at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
      at java.lang.reflect.Method.invoke(Method.java:498)
      at org.junit.internal.runners.TestMethodRunner.executeMethodBody(TestMethodRunner.java:99)
      at org.junit.internal.runners.TestMethodRunner.runUnprotected(TestMethodRunner.java:81)
      at org.junit.internal.runners.BeforeAndAfterRunner.runProtected(BeforeAndAfterRunner.java:34)
      at org.junit.internal.runners.TestMethodRunner.runMethod(TestMethodRunner.java:75)
      at org.junit.internal.runners.TestMethodRunner.run(TestMethodRunner.java:45)
      at org.junit.internal.runners.TestClassMethodsRunner.invokeTestMethod(TestClassMethodsRunner.java:71)
      at org.junit.internal.runners.TestClassMethodsRunner.run(TestClassMethodsRunner.java:35)
      at org.junit.internal.runners.TestClassRunner$1.runUnprotected(TestClassRunner.java:42)
      at org.junit.internal.runners.TestClassRunner.run(TestClassRunner.java:52)
      at org.junit.runner.JUnitCore.run(JUnitCore.java:121)
      at com.intellij.junit4.JUnit4IdeaTestRunner.startRunnerWithArgs(JUnit4IdeaTestRunner.java:68)
      at com.intellij.rt.execution.junit.IdeaTestRunner$Repeater.startRunnerWithArgs(IdeaTestRunner.java:47)
      at com.intellij.rt.execution.junit.JUnitStarter.prepareStreamsAndStart(JUnitStarter.java:242)
      at com.intellij.rt.execution.junit.JUnitStarter.main(JUnitStarter.java:70)
      Process finished with exit code 255
@@Prabhjyot.Mandla
here the full stack of error
4.5k 4 7 8
@thomas.gauroy,
Thank you for the details.
Can you please let us know if you are getting Error 403 only this specific request or all the requests?
@Prabhjyot.Mandla same result with all requests
4.5k 4 7 8
@thomas.gauroy,
The reason you are getting Error 403 is because the gatewayhost which you are using for the API call is incorrect. Secondly, the Date format in the request header should be in English and not regional language.
Please note :
The below API calls will have gatewayhost : rms-world-check-one-api-pilot.thomsonreuters.com
SEQ-pre-groups: Get my top-level groups
SEQ-pre-group: Get a specific group by ID
SEQ-pre-group-case-template: Get the case template for a group
SEQ-pre-country-list: Get the ISO country list
The below API calls will have gatewayhost: zfs-world-check-one-api-pilot.thomsonreuters.com
SEQ-zfs-api-sync-screen-simple: Perform Zero Footprint Synchronous Screening: Simple
SEQ-zfs-api-zfs-case-investigate-world-check-profile: Get a World-Check profile
Hope this helps.
