fetching organization data
hello, what method or api is used to get all data on organization? including company structure, personals connected to company and more...
world-checkworld-check-onedata
4.5k 4 7 8
@meirr,
When you use the above API call for screening organisation name you get results in the response, which have breif information on the matched organisations / entity. For fetching more details on a specific organisation, you will have to use the API call - 'SEQ-case-investigate-world-check-profile: Get a World-Check profile' using the reference-id received from the screening result.
Hope this helps.
4.5k 4 7 8
@meirr,
Thank you for your query.
In order to fetch the details of an organisation, please use the API call - 'SEQ-screen-sync-organisation: Perform Synchronous Screening: Organisation' to screening the organisation and it will provide you the list of matches in the response of the API call.
As of now it is not possible to fetch the list of personals connected to the company.
there is no api method for getting general details on certain company?
