Error 400 using country secondary fields
Hi, i tryng to create a new case (endpoint https://rms-world-check-one-api-pilot.thomsonreuters.com/v1/cases)
Using this body, i insert my new case correctly:
{"secondaryFields":[{"typeId":"SFCT_1","value":"MALE"},{"typeId":"SFCT_2","dateTimeValue":"1973-05-26"}],"entityType":"INDIVIDUAL","customFields":[],"groupId":"0a3687cf-5fe4-105f-9808-44b100000521","providerTypes":["WATCHLIST"],"name":"Mario Rossi"}
When i add a new country field in secondary fields, i receive error 400:
{"secondaryFields":[{"typeId":"SFCT_1","value":"MALE"},{"typeId":"SFCT_2","dateTimeValue":"1973-05-26"},{"typeId":"SFCT_4","Value":"ITA"}],"entityType":"INDIVIDUAL","customFields":[],"groupId":"0a3687cf-5fe4-105f-9808-44b100000521","providerTypes":["WATCHLIST"],"name":"Mario Rossi"}
Can someone help me?
world-checkworld-check-onedatascreening
Hello @mirko.fedele,
I looked and tested your code. I also received 400 error message in the postman.
After changing "Value" to "value" I've received 200 OK message.
The parameters names are casesensitive.
Could you please check it?
Best Regards
Kamil
{"secondaryFields":[{"typeId":"SFCT_1","value":"MALE"},{"typeId":"SFCT_2","dateTimeValue":"1973-05-26"},{"typeId":"SFCT_4","value":"USA"}],"entityType":"INDIVIDUAL","customFields":[],"groupId":"0a3687cf-5fe4-105f-9808-44b100000521","providerTypes":["WATCHLIST"],"name":"Mario Rossi"}
Perfect! I've received 200
Thanks!
