The data completeness for World Chek On Screening Result
Using the API, I wonder once I screen and retrieve a result on an Individual one month ago. Data returned saying he/she is a directors of two company (Co. A, Co.B). One month later, If I redo the screening and retrieve the result on the same person again, he/she is a directors of another two more company. Will the result returned just the delta data or complete set? Which means in the response can I find out if he/she is the directors of four company (Co.A, Co.B, Co.C, Co.D)?
world-checkworld-check-onedata
Hi @patrick14,
The response will be a complete set and not the delta based on the previous request.
Hope this helps
Rakesh
I believe the same for organization screening as well, which will be returning complete set. Am I right?
Hi @patrick14,
Yes you right.The screening response will be complete set for Organization as well.
Thanks,
Shilpi
