Background. I have IDS server running on host padh4, port 8500. I want to request a snapshot from IDS, and filter FIDs BID and ASK.
The following works ok from the command line:
COMMAND: curl "http://padh4:8500/ids-rest/json/quote/" -d '{"item": ["CSCO.O"],"filter": ["BID","ASK","TRDPRC_1"],"service": "IDN_RDF","token": "rharris"}' RESULT: {"stsCode":0,"stsTxt":"OK","result":[{"_service":"IDN_RDF","_qos":"RT0","_item":"CSCO.O","stsCode":0,"stsTxt":"OK","chainLink":[],"TRDPRC_1":"53.68","BID":"53.68","ASK":"53.69"}]}
I am trying to achieve the same result with an html page, code shown below.
<html> <head> <title>Form Example</title> <script LANGUAGE="JavaScript" type="text/javascript"> function display() { message = "{"; message += "\"item\" :" + document.form1.item.value + ","; message += "\"filter\" :" + document.form1.filter.value + ","; message += "\"service\" :" + document.form1.service.value + ","; message += "\"user\" :" + document.form1.user.value + ","; message += "\"expandChain\" :" + document.form1.expandChain.value + ","; message += "\"emptyLink\" :" + document.form1.emptyLink.value + ","; message += "\"chainLink\" :" + document.form1.chainLink.value; message += "}"; var form = document.createElement("form"); form.setAttribute("method", "post"); form.setAttribute("action", "http://padh4:8500/ids-rest/json/quote/"); var hiddenField = document.createElement("input"); hiddenField.setAttribute("type", "hidden"); hiddenField.setAttribute("name", "key"); hiddenField.setAttribute("value", message); form.appendChild(hiddenField); document.body.appendChild(form); form.submit(); } </script> </head> <body> <h1>Form Example</h1> Enter the following information. When you press the Display button, the data you entered will be displayed in a pop-up window. <form name="form1"> <p><b>Item:</b> <input TYPE="TEXT" SIZE="20" NAME="item"> </p> <p><b>Filter:</b> <input TYPE="TEXT" SIZE="30" NAME="filter"> </p> <p><b>Service: </b> <input TYPE="TEXT" SIZE="15" NAME="service"> </p> <p><b>User: </b> <input TYPE="TEXT" SIZE="15" NAME="user"> </p> <p><b>Expand Chain: </b> <input TYPE="TEXT" SIZE="15" NAME="expandChain"> </p> <p><b>Empty Link: </b> <input TYPE="TEXT" SIZE="15" NAME="emptyLink"> </p> <p><b>Chain Link: </b> <input TYPE="TEXT" SIZE="15" NAME="chainLink"> </p> <p><input TYPE="BUTTON" VALUE="Send POST" onClick="display();"></p> </form> </body> </html>
This page connects to padh4 on port 8500 ok, and seems to make the POST ok. The javascript takes the form data and builds a string, which is submitted via a hidden table. However, IDS returns the following error:
{"stsCode":402,"stsTxt":"PARSE_UNICODE_ERROR"}
The chrome debugger shows my POST was submitted as the value to a variable called "key". The format is close but not correct, hence the 402 error from IDS.
My issue is how to get the POST correctly formatted. Do I need to JSON.stringify the message? Or build it completely manually? How to get rid of the 'key' in the response?
Thanks in advance for all help.
