How to implement RFA provider with hotstandby enabled ?
We're implementing a RFA provider in OMM and the feature "hot standby" is enabled on our TREP infrastructure but we don't have any documentation about this feature.
Is it related to "warm standby" or is it totally different ?
In the RFA documentation, we can read about "warm standby":
"a provider can be told to run as an Active or a Standby server, where the Active will behave as usual. The Standby will respond to item requests only with the message header and will forward any state changing information."
Do we have to implement the same behavior for "hotstandby" ?
When starting our provider, we have a message like this telling that "hot standby" is enabled:
<!-- Incoming Message from 'mkddev306' on 'localhost' interface -->
<!-- Time: 18:23:39:356 -->
<!-- rwfMajorVer="14" rwfMinorVer="1" -->
<genericMsg domainType="RSSL_DMT_SOURCE" streamId="2" containerType="RSSL_DT_MAP" flags="0x14 (RSSL_GNMF_HAS_MSG_KEY|RSSL_GNMF_MESSAGE_COMPLETE)" dataSize="37">
  <key  flags="0x2 (RSSL_MKF_HAS_NAME)"  name="ConsumerStatus"/>
  <dataBody>
    <map flags="0x0" countHint="0" keyPrimitiveType="RSSL_DT_UINT" containerType="RSSL_DT_ELEMENT_LIST" >
      <mapEntry flags="0x0" action="RSSL_MPEA_ADD_ENTRY" key="1" >
        <elementList flags="0x8 (RSSL_ELF_HAS_STANDARD_DATA)">
          <elementEntry name="SourceMirroringMode" dataType="RSSL_DT_UINT" data="2"/>
        </elementList>
      </mapEntry>
     </map>
  </dataBody>
</genericMsg>
This message tells that our provider is on standby (cf. SourceMirroringMode = 2), so do we have to send only message with headers and no payload (like the "warm standby") ?
Thanks your answers.
Regards.
elektronrefinitiv-realtimetreprfawarm-standby
Refer to section 12.2 Hot Standby Requirements for Source Application in the ADH installation guide, each datafeed/source application must deliver the same update stream for each item open on the datafeed; i.e., the order of update delivery and the update’s data content must be the same for a given item.
Therefore, in Hot Standby mode, the source application of the standby server must send the same update messages as the source application of the active server.
Thanks for your reply.
