Can I subscribe to my own POSTs on same RFA connection?
I'm currently developing an application which uses an OMMConsumer and POST functionality to send out updates. Can I also subscribe to these updates to check that they are going out OK? I have tried to do this but on some case the RSSL.0 log file shows the POSTs going out
MESSAGE
Msg Type: MsgType.POST
Msg Model Type: MARKET_PRICE
Indication Flags: POST_INIT | POST_COMPLETE
Hint Flags: HAS_ATTRIB_INFO | HAS_ID | HAS_PUBLISHER_INFO
Publisher Address: 0xa65fc83
Publisher Id: 13292
AttribInfo
ServiceId: 8003
NameType: 1 (RIC)
Payload: 23 bytes
FIELD_LIST
FIELD_ENTRY 22: 4b0094c32b
FIELD_ENTRY 25: 4b009641ea
But shows no messages being received from the subscription, although the log suggests the subscription happened OK:
Received handle com.reuters.rfa.internal.session.omm.OMMSubHandleImpl@11c4c912
elektronrefinitiv-realtimetreprfaOMMpost
What are you posting to? (i.e. what is service 8003 ?). How do you the expect service 8003 to respond to your posting? As pointed out by David Thomas, how the posting is handled by the endpoint depends entirely on that endpoint. Most services do not accept postings at all. You also need to check if you get an ACK or a NACK back as a result of your posting.
Yes, you can subscribe to your own postings if what you are posting to acts as re-publisher. For example the ATS does this.
Hello @alan.bain
This is possible but your application would be subscribing to the service that it is posting to and as such it is entirely up to the provider application supporting the service as to what happens when it 1)receives a post message and 2)receives a subscription.
e
