Holiday List from TRTH
Is it possible to pull holiday list from TRTH API using ric's MY/Holiday, US/Holiday , SG/HOLIDAY, IN/HOLIDAY etc
tick-history-rest-api
11.3k 25 8 13
Hi @Kumar.warthak,
The Holiday list RICs are Speed Guide Pages where each row of data are provided in specific range of fields: ROW80_1 - ROW80_25. To access specific fields, you need to use TickHistoryRawExtraction report template which provides raw field-value format data. Also, the extraction date range could be at least seven days to ensure that Refresh message were received.
Please refer to the Speed Guide Pages section of the REST API User Guide document for more information. Also, I have created an article for this topic.
Below is the example of REST API request message.
POST https://hosted.datascopeapi.reuters.com/RestApi/v1/Extractions/ExtractRaw { "ExtractionRequest": { "@odata.type": "#ThomsonReuters.Dss.Api.Extractions.ExtractionRequests.TickHistoryRawExtractionRequest", "IdentifierList": { "@odata.type": "#ThomsonReuters.Dss.Api.Extractions.ExtractionRequests.InstrumentIdentifierList", "InstrumentIdentifiers": [ { "Identifier": "US/HOLIDAY", "IdentifierType": "Ric" } ], "ValidationOptions": { "AllowHistoricalInstruments": true }, "UseUserPreferencesForValidationOptions": false }, "Condition": { "MessageTimeStampIn": "GmtUtc", "ReportDateRangeType": "Range", "QueryStartDate": "2019-02-05T00:00:00.000Z", "QueryEndDate": "2019-02-12T00:00:00.000Z", "ExtractBy": "Ric", "SortBy": "SingleByRic", "DomainCode": "MarketPrice", "DisplaySourceRIC": true } } }
Result will be in CSV format.
Hi @veerapath.rungruengrayubkul
Thank you for the code, i am able to pull holiday's for all markets. I have a follow up question Is there a simple way to pull data for multiple RIC's, currently iam running as below:
"InstrumentIdentifiers": [ { "Identifier": "US/HOLIDAY", "IdentifierType": "Ric" } { "Identifier":"MY/HOLIDAY", "IdentifierType": "Ric" } { "Identifier": "SA/HOLIDAY", "IdentifierType": "Ric" } ],
@Kumar.warthak
Yes. You can add multiple instruments in the same request. Results of RIC will be generated in the same file, so application needs to parse the file to get result for each RIC. Below is the sample.
{ "Identifier": "US/HOLIDAY", "IdentifierType": "Ric" },
{ "Identifier": "MY/HOLIDAY", "IdentifierType": "Ric" },
