429 response is saved
I am following the flow of:
make a request
receive 202 with location header
poll the url from the location header until receive a 200
However it would appear that a "429 too many requests" response gets saved into the response of that location header.
You should be able to see this under X-Client-Session-Id:
6e8cdf96-0508-11e9-8014-525400a87d41_6908
I received a 202 with a location header, but after that I received a 429. And now, even though I am not making any other requests at the same time, your system keeps returning a 429.
dss-rest-apidatascope-selectdssjavaerror-429
13.7k 26 8 12
A 429 is returned if there are too many open concurrent HTTP extraction requests. Note that a request is considered open until the entire extraction has completed.
Hi @davet1
Please raise the service ticket for DSS support team via MyRefinitiv. In the product field, select "Reuters DataScope Select".
Thanks.
