[EMA C++]How to get chain of AMEX \ ARCA \ BATS
hello
I develop with EMA C++.
I can request chain of HKSE with the code "0#/MBD.HK"
Which code I can use to get the chain of AMEX ARCA BATS NASDAQ NYSE NASDAQ BASIC
elektronelektron-sdkrrtema-apirefinitiv-real-time
Hi @luxiangyuan
As mentioned previously, the message means your username (DACS ID) 'user1' is not entitled to consume those RICs. Please speak to your Refinitiv account manager OR local market data team to see if they can permission you in DACS for the data you require.
Once your entitlements / permissions are changed you should be able to request those instruments.
hello
now I can request chain successfully!
but I can not request some stock code from "NASDAQ" and "NASDAQ BASIC".
dose this becasuse the "permission "???
Hi @luxiangyuan
I have asked your Refinitiv Account Manager to contact and explain about permissions and entitlements to you.
'Access Denied' message means you are not permissioned for that Data.
Regards,
Umer
ok, thank you .
because I can request some data successfully,
only can not request "NASDAQ" and "NASDAQ BASIC".
so I doubt if I write the code with some mistake.
thank you, thank you very much.
hello
