EMA - Query
I am new here, trying to implement EMA to get market pricing data for a list of securities. This list will be updated daily. We will be using Solace topics to subscribe. Can we subscribe to a dynamic list of securities and not currency, if yes, how? Also, can we refresh this list dynamically or will we need to restart the process every morning with a new itemlist?
elektronelektron-sdkrrtema-apirefinitiv-real-time
Hi @aastha.sharma
EMA uses RICs for the symbology when consuming Refinitiv Real-Time data.
From your post, can I assume you are consuming data from a Solace feed - via a Refinitiv RTDS system?
Whilst all of our EMA examples specify the required RIC/RICs at startup - you are free to subscribe to instruments (available on your feed) - as and when required.
You can also close all or individual instruments as and when required.
You can subscribe to an instrument by calling registerClient for one or more instruments
  • using a Batch request for multiple instruments with a single registerClient call
  • or calling registerClient individually for each instrument
For each valid instrument you subscribe to, a stream is created and each stream is assigned a unique handle.
You will need to store the handle for each item:
UInt64 handle = consumer.registerClient( ReqMsg().serviceName( "MY_FEED" ).name( "IBM.N" ), client )
and then use the handle to unsubscribe each item you no longer require it. e.g.
_pOmmConsumer->unregister(handle)
for Batch requests, the handle would have to be extracted from the on onRefreshMsg() callback for each subscribed instrument, as the handle returned for a batch request will be closed as soon as the batch request is accepted.
EMA Consumer Example 300 demonstrates close for a subscribed item.
Thanks! Also, we want to stream the market price for a list of nasdaq securities (US and Canada) throughout the day, was wondering where can I find a list of RIC's to subscribe to?
Hi @aastha.sharma
You can either
