There are different types of connection type(e.g (RSSL_CONN_TYPE_SOCKET) ? Which connection_type is suitable for us? And how to use/test that conn_type. Which type of data we will receive for each connection type?
elektronelektron-sdkrrtema-apirefinitiv-real-time
@khushboo.kumari
It depends on the server that you are connecting to.
For example, if the server is the Refinitiv Real-Time Optimized, you can use the RSSL_ENCRYPTED connection type.
If the server is Refinitiv Real-Time Distribution System (RTDS), direct feed, or edge device, the connection type could be RSSL_SOCKET.
Please let us know the server that you are using.
