we found our binary coredump in RFA dynamic library file. Following is the call stack information in the core file. The error was raised in Thread #1, and as you can see from the stack information, this Thread is all RFA LIB code.
The RFA LIB version we are using is rfa_v7.6.l1 for Linux.
(gdb) info thread Id Target Id Frame 2 Thread 0x7f1067810880 (LWP 10431) 0x00007f1064d5fab2 in pthread_cond_timedwait@@GLIBC_2.3.2 () from /lib64/libpthread.so.0 * 1 Thread 0x7f1040e39700 (LWP 10445) 0x00007f1062e4c5d7 in raise () from /lib64/libc.so.6 (gdb) bt #0 0x00007f1062e4c5d7 in raise () from /lib64/libc.so.6 #1 0x00007f1062e4dcc8 in abort () from /lib64/libc.so.6 #2 0x00007f10671da33d in __RFA_ProblemReport () from /usr/local/lib/libRFA_Common.so #3 0x00007f1065e038ce in rfa::support::Thread::startWrapper(void*) () from /usr/local/lib/libRFA_SessionLayer.so #4 0x00007f1064d5bdf5 in start_thread () from /lib64/libpthread.so.0 #5 0x00007f1062f0d1ad in clone () from /lib64/libc.so.6 (gdb) thread 2 [Switching to thread 2 (Thread 0x7f1067810880 (LWP 10431))] #0 0x00007f1064d5fab2 in pthread_cond_timedwait@@GLIBC_2.3.2 () from /lib64/libpthread.so.0 (gdb) bt #0 0x00007f1064d5fab2 in pthread_cond_timedwait@@GLIBC_2.3.2 () from /lib64/libpthread.so.0 #1 0x00007f10671d9d96 in rfa::support::ConditionVariable::wait(long, long) () from /usr/local/lib/libRFA_Common.so #2 0x00007f10671cfe87 in rfa::common::EventQueueImpl::dispatch(long) () from /usr/local/lib/libRFA_Common.so #3 0x0000000000445976 in ?? () #4 0x00000000006225da in ?? () #5 0x0000000000445a67 in ?? () #6 0x000000000043949a in ?? () #7 0x00007f1062e38af5 in __libc_start_main () from /lib64/libc.so.6 #8 0x000000000041dce9 in ?? ()
We've checked there is no exception in our application log. The following is the error reported by RFA LIB's own error log:
$ cat RFA_000028BF_00000000_20180622_083002.log RFA Internal failure Application: RFA Process Id: 0x28BF File: Support/OS/Impl/Thread.cpp Line: 59 Problem: Unhandled exception caught
Can anyone help me how to fix this issue?
