RFA C++ 8.2: Which of the Linux release lib files should be used with RHEL 7.9?
The RFA 8.2 C++ release for Linux contains 2 library versions that are compatible with 64-bit archs.: 1. OL7_64_GCC482 2. RHEL6_64_GCC444. The RFA C++ 8.2 release notes mentions that these have been tested with:
1. RHEL6_64_GCC444 : Red Hat Enterprise Linux Server release 6.10 with RFA Lib GCC 7.4.0
2. OL7_64_GCC482: Red Hat Enterprise Linux Server release 7.7 with RFA Lib GCC 4.8.2
For an application that is going to be run on RHEL 7.9, should I prefer to use the RFA libraries OL7_64_GCC482 because they are proven to have been used with a close RHEL version (7.7) or should I go with RHEL6_64_GCC444 because that's been built on RHEL (even though it is only tested against RHEL 6.10)? Thanks
treprfarfa-apic++linux
@mparthasarathy
According to the API Compatibility Matrix and the README file, you should use OL7_64_GCC482 on RHEL7.x.
