RFA7.2 failed to connect RMDS in Linux 6.4
Greetings
Currently, we are migrating our RFA7.2 based program from windows to Linux, but we found connection issue as below:
Received CONNECTION_EVENT: myNamespace::SLLConnection
{ state: DOWN, code: NONE, text: "Not connected: com.reuters.mainloop.DispatchException: Could not determine position"}
RFA: Version = 7.2.0.L1.all, Date = Mon May 16 15:42:38 CST 2016, Jar Path = No jar file available. Executed using class files.
DACS: Version = 7.0.1.F4, Date = Mon May 16 15:42:48 CST 2016, Jar Path = Is bundled into rfa.jar
Also, we've has done the following check:
1) Java in Linux is 1.6
2) RMDS is accessible from Linux
3) iptables is closed.
4) configuration has been imported via Java.util.Preferences.
Any idea what happened, or any suggestion for us to debug?
Thank you very much for any reply.
treprfarfa-apiconnectionlinux
9.5k 10 5 7
This looks like the old issue I have found in RFA application on Red Hat Linux when RFA called the java function, InetAddress.getLocalHost() but it failed and threw the error message which indicated that Java could not found IP address of the local host. The old issue was fixed by including these following lines to /etc/hosts file
127.0.0.1 localhost.localdomain localhost
<assigned_ip> < hostname>
-The <assigned_ip> is a site-local IP address e.g. 192.168.x.x. or 10.x.x.x.
-The <hostname> is what returned from hostname command.
Hope this can solve your problem.
@Pimchaya.Wongrukun
Currently, we are migrating our RFA7.2 based program from windows to Linux,but in development environment,everything is ok,but when I deploy the project to the ST environment,it failed to connect RMDS,I compare and the only difference is the /etc/hosts file,but I have no permissions to amend the hosts file in ST,the connection issue as below:
Any suggestion for us to debug?
9.5k 10 5 7
@shishuoxinyux
Based on my experience, the problem can be solved by editing /etc/hosts file according to my suggestion above. Hence, please contact the admin of ST environment for editing the /etc/hosts file.
