Calling TRTH REST API from SSIS
I have a C# test console app that uses the REST API SDK . It works fine.
I copied the code to a script task within SSIS and now I get the error "Exception has been thrown by the target of an invocation". All I am doing at this point is getting a new UsersContext.
Has anyone successfully called the REST API from SSIS using the SDK?
tick-history-rest-apissis
You need to install all REST API assemblies into GAC. You can do it by running the command (gacutil -i) under Developer Command Prompt for Visual Studio with Run as administrator.
C:\Users\Downloads\RESTAPIToolkit>gacutil -i ThomsonReuters.Dss.RestApi.Client.dll
C:\Users\Downloads\RESTAPIToolkit>gacutil -i ThomsonReuters.Dss.Core.RestApi.Common.dll
C:\Users\Downloads\RESTAPIToolkit>gacutil -i Microsoft.OData.Client.dll
C:\Users\Downloads\RESTAPIToolkit>gacutil -i Microsoft.OData.Edm.dll
C:\Users\Downloads\RESTAPIToolkit>gacutil -i Microsoft.OData.Core.dll
C:\Users\Downloads\RESTAPIToolkit>gacutil -i Microsoft.Spatial.dll
C:\Users\Downloads\RESTAPIToolkit>gacutil -i Newtonsoft.Json.dll
