Tick History Version 2 - Can you verify the uncompressed file size of a file for me?
I've downloaded the file NYQ-2017-12-05-NORMALIZEDMP-Data-1-of-1.csv.gz from the web services... I notice that the compressed file size is listed as 1,315,264 (e.g. 1.3 GB file) ... However, for some reason, when I uncompress this it uncompresses to 240 MB (specifically, 240,322). Can you tell me what the uncompressed file size of this file is supposed to be?
tick-history-rest-api
11.3k 25 8 13
The uncompressed file size of the file is supposed to be around 24 GB (24,002,128,910 Bytes). I am able to uncompress the file with 7-Zip app. According to gzip manual, the uncompressed size and compression ratio are listed incorrectly for uncompressed files 4 GB and larger. I am not sure if this can be related to the issue.
Which tool/programming did you use to uncompress the file?
Below is the screenshot of the manual.
Thanks - also what is the compressed file size?
The compressed file size is 1,346,830,078 Bytes. It looks different from the file size you provided. Can you re-download the file?
