​Just wonder, if the authentication is done via OAuth v1 like this page mentioned - https://github.com/scalaj/scalaj-http Or it is a custom authentication method that Reuters custom build? Product TRTHv2 API
Product TRTHv2 API
tick-history-rest-apioauth
TRTH V2 REST API uses token based authentication.
First, to get a token, the application need to send HTTP POST to https://hosted.datascopeapi.reuters.com/RestApi/v1/Authentication/RequestToken with Username and Password in the body.
If the credential is valid, the application will receive HTTP Response with status 200 OK and a token in the body.
Next, this token will be added in the HTTP header for subsequent requests. For example:
Headers:
Prefer: respond-async
Content-Type: application/json
Authorization: Token F0ABE9A3FFF2E02E10AE2765ED872C59B8CC3B40EBB61B30E295E71DE31C254B8648DB9434C2DF9299FDC668AA123501F322D99D45C8B93438063C912BC936C7B87062B0CF812138863F5D836A7B31A32DCA67EF07B3B50B2FC4978DF6F76784FDF35FCB523A8430DA93613BC5730CDC310D4D241718F9FC3F2E55465A24957CC287BDEC79046B31AD642606275AEAD76318CB221BD843348E1483670DA13968D8A242AAFCF9E13E23240C905AE46DED9EDCA9BB316B4C5C767B18DB2EA7ADD100817ADF059D01394BC6375BECAF6138C25DBA57577F0061
The token remains valid for 24 hours. You can reuse a token as often as you like within that 24-hour period. For more information, please refer to REST API Tutorial 1: Connecting to the server.
To add, once you get the authentication token you can set it using the following:
Http(requestUrl)
  .headers(requestHeaders)
  .postData(reqJson)
