Example in MarketDepth request, I can set view=LegacyLevel2 to get raw data.
There is no option to select raw data in the TimesAndSales report template. It likely is the TickHistoryRawExtraction which provides raw domain data in a format unaltered from that transmitted on the Thomson Reuters Elektron real-time network.
You can find all available options in each report templates in the REST API Reference Tree. There is also information in the Tick History GUI User Guide.
Thanks @veerapath.rungruengrayubkul
I am unable to access the first page you provided i.e. REST API Reference Tree
Does it require a special access?
@muneish.adya The page require DSS credential for access. You need to login with your DSS username and password .
TRTH V2 has integrated with the existing DataScope Select platform (DSS). Let say it is the username/password you use for TRTH REST API.
anyone? is there a place which tells about all the views available in various request types. more detailed documentation would be helpful.
