Instrument and REF file type missing
We were trying to download below files, it was not listed. Please help us here.
REF-Data-CUSIP-SEDOL and Instruments-CUSIP-SEDOL
tick-history-rest-api
@Ayan
Could you please specify the exchange name and date? Therefore, we can verify it.
It is across all the availble dates. However it is available is DSS. We can see from Data Scope. But while listing the file details under exchanges it is not getting listed.
@Ayan, can you tell us how you are listing the files ? If it is through the API then please share the call endpoint and body. That will help us understand and respond.
I have reviewed the above query and confirm that you need to have permissions to CUSIP, SEDOL GICS to access Instruments-CUSIP-SEDOL-GICS and REF-Data-CUSIP-SEDOL-GICS files.
As an alternative, you can refer to the following:
  • 1)<Instruments-1-of-1.csv.gz> instead of Instruments-CUSIP-SEDOL-GICSs
  • 2)<REF-Data-1-of-1.csv.gz> instead of REF-Data-CUSIP-SEDOL-GICS
The difference between these couple of files is the “CUSIP-SEDOL-GICS” will provide CUSIP-SEDOL-GICS details others don’t. The rest of the data remain same.
Regards,
Beera
I used this extraction for NAS.
/StandardExtractions/UserPackageDeliveryGetUserPackageDeliveriesByPackageId(PackageId='0x04f21a8d26059cb1')
It returns NAS-2017-09-05-Instruments-CUSIP-SEDOL-GICS-1-of-1.csv.gz and NAS-2017-09-05-REF-Data-CUSIP-SEDOL-GICS-1-of-1.csv.gz.
nas.txt
nas.txt (22.0 KiB)
We are using below command, but still not able to see those files.
curl -k -X GET -H 'Content-Type: application/json' -H 'Prefer: odata.maxpagesize=600; respond-async' -H 'Accept-Charset: UTF-8' -H 'Authorization: Token xxxxx' https://10.192.6.221/RestApi/v1/StandardExtractions/UserPackageDeliveryGetUserPackageDeliveriesByPackageId%28PackageId%3D%270x04f21a8d26059cb1%27%29
Is it possible that due to subscription restriction we are not able to see the file names? Please help.
I used the above command. My result is different from yours. It contains "NAS-2017-09-05-Instruments-CUSIP-SEDOL-GICS-1-of-1.csv.gz" and "NAS-2017-09-05-REF-Data-CUSIP-SEDOL-GICS-1-of-1.csv.gz".
I will contact TRTH support team to verify the problem.
