In a Corporate Actions request, what is the field to get the announcement date for earnings ? "Effective date" does not return anything.
tick-history-rest-api
Regarding the announcement date for corporate earnings, you can refer to the field "Earnings Announcement Date" in Standard Events Report Template of TRTH v2.
Currently, you may see the field "Earnings Announcement Date" as locked hence you will not receive the value in that field. I confirm that the full corax fields on Corporate Actions (Standard Events Report Template) will be available from Monday, Oct. 23rd 2017.
Upon which you will receive the data as below:RICCorporate Actions TypeEarnings Announcement DateDividend Announcement DateKLOVb.STEAR2/10/2017 KLOVb.STDIV 2/11/2016
Regards,
Beera Rajesh
Upgrade Specialist - TRTH
Hi Thomas,
The JIRA DSS-24145 has been fixed and now you can access the Full Corax Template. Regarding the announcement date for corporate earnings, you can refer to the field "Earnings Announcement Date" in Standard Events Report Template of TRTH v2.
Regards,
Beera
