MM files download
We are looking to download Market by Maker files. What API do we need to use. Attaching a code snippet for MBO. I believe it will not a lot of differences between MBO and MM.
allcom.txt
allricsfile.txt
tick-history-rest-apimarket-maker
allcom.txt (509 B)
allricsfile.txt (1.6 KiB)
To request raw Market Maker data, you just change the value of View from RawMarketByOrder to RawMarketMaker.
  "ExtractionRequest": {
    "@odata.type": "#ThomsonReuters.Dss.Api.Extractions.ExtractionRequests.TickHistoryMarketDepthExtractionRequest",
    "IdentifierList": {
      "InstrumentIdentifiers": [
          "@odata.type": "#ThomsonReuters.Dss.Api.Search.HistoricalSearchResult",
          "Identifier": "AAPC.O",
          "IdentifierType": "Ric"
      "ValidationOptions": {
        "AllowHistoricalInstruments": true
    "Condition": {
      "View": "RawMarketMaker",
      "MessageTimeStampIn": "GmtUtc",
      "ReportDateRangeType": "Range",
      "QueryStartDate": "2017-08-07T00:00:00.000Z",
      "QueryEndDate": "2017-08-07T23:59:59.000Z",
      "DisplaySourceRIC": true
As mentioned by Rakesh.Singh, MM data is only available for the NASDAQ Consolidated exchanges i.e. NAQ, NSQ and NMQ.
All valid options for View are:
<EnumType Name="TickHistoryMarketDepthViewOptions">
<Member Name="RawMarketByPrice" Value="0"/>
<Member Name="RawMarketByOrder" Value="1"/>
<Member Name="RawMarketMaker" Value="2"/>
<Member Name="LegacyLevel2" Value="3"/>
<Member Name="NormalizedLL2" Value="4"/>
</EnumType>
Hi Ayan
That's right. Requests for MM (Market Makers) will be very similar to requests for MBO data. Please keep in mind that MM data is only available for the NASDAQ Consolidated exchanges i.e. NAQ, NSQ and NMQ.
