Ghost list
Hello everybody,
With the web interface (https://hosted.datascope.reuters.com/dataScope) I created a list with a few instruments, a schedule with a template and a trigger.
I obtained the data.
I am now trying to obtain it by code, to master the API.
ReportExtraction re = extractionsContext.ReportExtractionOperations.Get("2"); // example
Schedule s = extractionsContext.ScheduleOperations.Get(re.ScheduleId);
EntityList l = extractionsContext.EntityListOperations.Get(s.ListId);
The two first lines seem OK, but "l", the EntityList, remains null, whereas the identifier in s.ListId corresponds to what appears in the URL in the web interface.
What did I miss ?
tick-history-rest-api
13.7k 26 8 12
@hubert.Canevet.external, with the GUI, did you create an instrument list or an entity list ? I'm guessing (from the initial part of your query) that you created an instrument list.
To retrieve the instrument list from your schedule s, you can use:
InstrumentList myList = extractionsContext.InstrumentListOperations.Get(s.ListId);
After that you could display the Instrument list list ID:
Console.WriteLine("Returned instrument list ID: " + myList.ListId);
Oh nice, thank you very much.
Still an interrogation to go further.
myList.Count gives the number of instruments, how do I get them individually ?
I should have thought to myList.Items, but it has no item.
We have to distinguish between myList.Count and myList.Items.Count, and in the first case I do not see how to get the elements.
I think I got it :
IDssEnumerable<InstrumentListItem> listInst = extractionsContext.InstrumentListOperations.GetAllInstruments(myList);
I was too slow to answer, you found it on your own, great. Thank you for sharing your solution !
Sorry about the order, this is supposed to be the fourth message (maybe last).
