While trying to get the session token by using curl command, getting below error.
{"error":{"message":"Invalid username or password"}}
However we are able to login through GUI using same credentails. Also using SOAP UI we can request the token and get it back in response. Below is full curl command.
curl -H "Content-Type: application/json" -H "Prefer: respond-async" -X POST -d'{"Credentials": {"Username": "Your Username","Password": "Your Password"}}' https://hosted.datascopeapi.reuters.com/RestApi/v1/Authentication/RequestToken
Please help.
