how could I access libre rate and centre bank rate. e.g. GBBASE= ,GBP1MFSR= from the Java code and Trth API 2
Hi @bin and all,
This is the response from TR content team:
The RIC GBBASE= shows central bank rate and do not update regularly as they update only when there is a rate change from the Central Bank. And there is no specific pattern for the rates change.
It is the rate which UK commercial banks charge their most credit-worthy customers. The rates on the RIC are updated whenever the Bank of England amends the rates.
Please find the below fields that are updated for the RIC <GBBASE=>
FID 15 CURRENCY FID 22 BID FID 23 BID_1 FID 24 BID_2 FID 393 PRIMACT_1 FID 394 PRIMACT_2 FID 395 PRIMACT_3 FID 875 VALUE_DT1 FID 876 VALUE_DT2 FID 877 VALUE_DT3 FID 1275 GN_TXT32_1
I tried
{"ExtractionRequest":{"@odata.type":"#ThomsonReuters.Dss.Api.Extractions.ExtractionRequests.ElektronTimeseriesExtractionRequest","ContentFieldNames":["Trade Date","Last"],"IdentifierList":{"@odata.type":"#ThomsonReuters.Dss.Api.Extractions.ExtractionRequests.InstrumentIdentifierList","InstrumentIdentifiers":[{"Identifier":"GBBASE=","IdentifierType":"Ric"}],"ValidationOptions":{"AllowHistoricalInstruments":true},"UseUserPreferencesForValidationOptions":false},"Condition":{"StartDate":"2010-08-29T00:00:00.000Z","EndDate":"2016-09-29T23:59:59.999Z"}}}
But it looks no data reply. Could you provide some helps?
