do you have sample to use Scheduler to get corp event, because I need set the decimal of dividend, how could I do this, could I have a request sample?
what's post URL I should use for this template?
I got try to create a following report template and get bad request, any idea?
{"@odata.type":"#ThomsonReuters.Dss.Api.Extractions.ReportTemplates.CorporateActionsStandardReportTemplate","ShowColumnHeaders":false,"Name":"test1Name_TTemplate","Headers":[],"Trailers":[],"ContentFields":[{"FieldName":"Corporate Actions ID","Format":null},{"FieldName":"Corporate Actions Type","Format":null},{"FieldName":"Corporate Action Notes","Format":null},{"FieldName":"Delete Marker","Format":null},{"FieldName":"Event Status","Format":null},{"FieldName":"Capital Change Announcement Date","Format":null},{"FieldName":"Capital Change Deal Date","Format":null},{"FieldName":"Capital Change Ex Date","Format":null},{"FieldName":"Effective Date","Format":null},{"FieldName":"Capital Change Event Type","Format":null},{"FieldName":"Actual Adjustment Factor","Format":{"@odata.type":["#ThomsonReuters.Dss.Api.Extractions.ReportTemplates.ContentFieldNumberFormat"],"DecimalPlaces":[12],"DecimalSeparator":["Period"],"UseLeadingZero":[false],"NegativeSignPosition":["Before"],"UseThousandSeparator":[false],"UseTrailingZero":[false]}},{"FieldName":"New Shares Terms","Format":null},{"FieldName":"Old Shares Terms","Format":null},{"FieldName":"Dividend Pay Date","Format":null},{"FieldName":"Dividend Announcement Date","Format":null},{"FieldName":"Dividend Ex Date","Format":null},{"FieldName":"Dividend Payment Type","Format":{"@odata.type":["#ThomsonReuters.Dss.Api.Extractions.ReportTemplates.ContentFieldNumberFormat"],"DecimalPlaces":[12],"DecimalSeparator":["Period"],"UseLeadingZero":[false],"NegativeSignPosition":["Before"],"UseThousandSeparator":[false],"UseTrailingZero":[false]}},{"FieldName":"Dividend Rate","Format":{"@odata.type":["#ThomsonReuters.Dss.Api.Extractions.ReportTemplates.ContentFieldNumberFormat"],"DecimalPlaces":[12],"DecimalSeparator":["Period"],"UseLeadingZero":[false],"NegativeSignPosition":["Before"],"UseThousandSeparator":[false],"UseTrailingZero":[false]}},{"FieldName":"Currency Code","Format":null}],"Condition":{"ReportDateRangeType":"Range","QueryStartDate":"2006-01-01T00:00:00.000Z","QueryEndDate":"2017-04-27T23:59:59.999Z","IncludeInstrumentsWithNoEvents":true,"IncludeNullDates":false,"ExcludeDeletedEvents":true,"IncludeCapitalChangeEvents":true,"IncludeDividendEvents":true,"IncludeEarningsEvents":false,"IncludeMergersAndAcquisitionsEvents":false,"IncludeNominalValueEvents":false,"IncludePublicEquityOfferingsEvents":false,"IncludeSharesOutstandingEvents":false,"IncludeVotingRightsEvents":false,"CorporateActionsCapitalChangeType":"CapitalChangeAnnouncementDate","CorporateActionsDividendsType":"DividendAnnouncementDate"}}
I format my message to make it easy to be read.
"Headers":[
"Trailers":[
"ContentFields":[
"Format":null
"Format":null
"Format":null
"Format":null
"Format":null
"Format":null
"Format":null
"Format":null
"Format":null
"Format":null
"Format":{
"@odata.type":"#ThomsonReuters.Dss.Api.Extractions.ReportTemplates.ContentFieldNumberFormat",
"DecimalPlaces":12,
"DecimalSeparator":"Period",
"UseLeadingZero":false,
"NegativeSignPosition":"Before",
"UseThousandSeparator":false,
"UseTrailingZero":false
"Format":null
"Format":null
"Format":null
"Format":null
"Format":null
"Format":{
"DecimalPlaces":12,
"Format":{
"DecimalPlaces":12,
"Format":null
"Condition":{
@bin, the easiest way to debug such issues is to copy your request into Postman, and test it from there. That is exactly what I did to solve this. The error message I initially got was:
"Malformed request payload: Syntax error at Line 18, Char 147: Invalid array element type for property '@odata.type'. Expected element type of 'ThomsonReuters.Dss.Api.Extractions.ReportTemplates.ContentFieldFormat', but found 'System.String'. {\"FieldName\":\"Actual Adjustment Factor\",\"Format\":{\"@odata.type\":[\"#ThomsonReuters.Dss.Api.Extractions.ReportTemplates.ContentFieldNumberFormat\"
Checking that line I saw that there were square brackets around all values:
I therefore removed them:
{"FieldName":"Actual Adjustment Factor","Format":{"@odata.type":"#ThomsonReuters.Dss.Api.Extractions.ReportTemplates.ContentFieldNumberFormat","DecimalPlaces":12,"DecimalSeparator":"Period","UseLeadingZero":false,"NegativeSignPosition":"Before","UseThousandSeparator":false,"UseTrailingZero":false}},
I also removed them from the other 2 lines that had these useless square brackets.
After that I got a different error message:
"Validation Errors:Invalid Format for content FieldName \"Dividend Payment Type\". Expected \"ThomsonReuters.Dss.Extractions.ReportTemplates.ContentFieldTextFormat\" but actual was \"ThomsonReuters.Dss.Extractions.ReportTemplates.ContentFieldNumberFormat\"
The message is self explanatory: the dividend payment type is a text, not a number, so it cannot be formatted like a number. After removing the formatting options for that field the request worked fine.
I hope this short explanation will help you understand how you can easily debug such issues.
Here is the corrected body for that query:
{ "@odata.type":"#ThomsonReuters.Dss.Api.Extractions.ReportTemplates.CorporateActionsStandardReportTemplate", "ShowColumnHeaders":false, "Name":"test1Name_TTemplate", "Headers":[], "Trailers":[], "ContentFields":[ {"FieldName":"Corporate Actions ID","Format":null}, {"FieldName":"Corporate Actions Type","Format":null}, {"FieldName":"Corporate Action Notes","Format":null}, {"FieldName":"Delete Marker","Format":null}, {"FieldName":"Event Status","Format":null}, {"FieldName":"Capital Change Announcement Date","Format":null}, {"FieldName":"Capital Change Deal Date","Format":null}, {"FieldName":"Capital Change Ex Date","Format":null}, {"FieldName":"Effective Date","Format":null}, {"FieldName":"Capital Change Event Type","Format":null}, {"FieldName":"Actual Adjustment Factor","Format":{"@odata.type":"#ThomsonReuters.Dss.Api.Extractions.ReportTemplates.ContentFieldNumberFormat","DecimalPlaces":12,"DecimalSeparator":"Period","UseLeadingZero":false,"NegativeSignPosition":"Before","UseThousandSeparator":false,"UseTrailingZero":false}}, {"FieldName":"New Shares Terms","Format":null}, {"FieldName":"Old Shares Terms","Format":null}, {"FieldName":"Dividend Pay Date","Format":null}, {"FieldName":"Dividend Announcement Date","Format":null}, {"FieldName":"Dividend Ex Date","Format":null}, {"FieldName":"Dividend Payment Type","Format":null}, {"FieldName":"Dividend Rate","Format":{"@odata.type":"#ThomsonReuters.Dss.Api.Extractions.ReportTemplates.ContentFieldNumberFormat","DecimalPlaces":12,"DecimalSeparator":"Period","UseLeadingZero":false,"NegativeSignPosition":"Before","UseThousandSeparator":false,"UseTrailingZero":false}}, {"FieldName":"Currency Code","Format":null} ], "Condition":{"ReportDateRangeType":"Range","QueryStartDate":"2006-01-01T00:00:00.000Z","QueryEndDate":"2017-04-27T23:59:59.999Z","IncludeInstrumentsWithNoEvents":true,"IncludeNullDates":false,"ExcludeDeletedEvents":true,"IncludeCapitalChangeEvents":true,"IncludeDividendEvents":true,"IncludeEarningsEvents":false,"IncludeMergersAndAcquisitionsEvents":false,"IncludeNominalValueEvents":false,"IncludePublicEquityOfferingsEvents":false,"IncludeSharesOutstandingEvents":false,"IncludeVotingRightsEvents":false,"CorporateActionsCapitalChangeType":"CapitalChangeAnnouncementDate","CorporateActionsDividendsType":"DividendAnnouncementDate" } }
Added later, to answer your second query, on the URL:
The answer is in the API Reference Tree, here. Click on Step 2 and HTTP request.
This is the end point URL:https://hosted.datascopeapi.reuters.com/RestApi/v1/Extractions/CorporateActionsStandardReportTemplates
I modefied my code and test via postman and my java application
I got
"error": {
"message": "The request is invalid."
This is my request
"Headers":[
"Trailers":[
"ContentFields":[
"Format":null
"Format":null
"Format":null
"Format":null
"Format":null
"Format":null
"Format":null
"Format":null
"Format":null
"Format":null
"Format":{
"DecimalPlaces":12,
"Format":null
"Format":null
"Format":null
"Format":null
"Format":null
"Format":null
"Format":{
"DecimalPlaces":12,
"Format":null
"Condition":{
