EMA Java: Possible to use Batch and View at the same time?
I run `example360__MarketPrice__View` and `example370__MarketPrice__Batch`. Both worked fine.
I would like to combine Batch and View to reduce heap consumption.
But the following code, which I tried to merge example360 into example370, leads to an error.
public class Consumer
	public static void main(String[] args)
		OmmConsumer consumer = null;
		try
			AppClient appClient = new AppClient();
			consumer  = EmaFactory.createOmmConsumer(EmaFactory.createOmmConsumerConfig().host("10.15.1.52:14002").username("new_user"));
			OmmArray arrBatch = EmaFactory.createOmmArray();
			arrBatch.add(EmaFactory.createOmmArrayEntry().ascii("/7203.T"));
			arrBatch.add(EmaFactory.createOmmArrayEntry().ascii("/2432.T"));
			ElementList batch = EmaFactory.createElementList();
			batch.add(EmaFactory.createElementEntry().array(EmaRdm.ENAME_BATCH_ITEM_LIST, arrBatch));
			OmmArray arrayView = EmaFactory.createOmmArray();
			arrayView.fixedWidth(2);
			arrayView.add(EmaFactory.createOmmArrayEntry().intValue(6));
			arrayView.add(EmaFactory.createOmmArrayEntry().intValue(22));
			arrayView.add(EmaFactory.createOmmArrayEntry().intValue(25));
			ElementList view = EmaFactory.createElementList();
			view.add(EmaFactory.createElementEntry().uintValue(EmaRdm.ENAME_VIEW_TYPE, 1));
			view.add(EmaFactory.createElementEntry().array(EmaRdm.ENAME_VIEW_DATA, arrayView));
			consumer.registerClient(EmaFactory.createReqMsg().serviceName("ELEKTRON_DD").payload(view).payload(batch), appClient);
			Thread.sleep(60000);			// API calls onRefreshMsg(), onUpdateMsg() and onStatusMsg()
		catch (InterruptedException | OmmException excp)
			System.out.println(excp.getMessage());
		finally
			if (consumer != null) consumer.uninitialize();
And the error is:
11 10, 2016 6:38:36 午後 com.thomsonreuters.ema.access.SingleItem rsslSubmit
重大: loggerMsg
    ClientName: SingleItem
    Severity: Error
    Text:    Internal error: rsslChannel.submit() failed in SingleItem.submit(RequestMsg)RsslChannel 0
	Error Id -1
	Internal sysError 0
	Error Location ItemHandler.extractViewFromMsg
	Error Text :ViewData element not found <-26>
loggerMsgEnd
Also, when I swap the order of `.payload(view).payload(batch)` to `.payload(batch).payload(view)`, the error is:
Failed to open or modify item request. Reason: ReactorReturnCodes.FAILURE. Error text: :ItemList not found.
11 10, 2016 6:52:24 午後 com.thomsonreuters.ema.access.SingleItem rsslSubmit
重大: loggerMsg
    Severity: Error
	Error Id -1
	Internal sysError 0
	Error Location WlItemHandler.handleBatchRequest
	Error Text :ItemList not found.
loggerMsgEnd
Could you tell me how to use both Batch and View at the same time?
Thank you.
elektronrefinitiv-realtimeelektron-sdkrrtema-apielektron-message-apibatch
11.3k 25 8 13
The Batch and View elementEntry needs to be in the same element list. Please try the following code.
ElementList batchView = EmaFactory.createElementList();
batchView.add(EmaFactory.createElementEntry().array(EmaRdm.ENAME_BATCH_ITEM_LIST, arrayBatch));
batchView.add(EmaFactory.createElementEntry().uintValue(EmaRdm.ENAME_VIEW_TYPE, 1));
batchView.add(EmaFactory.createElementEntry().array(EmaRdm.ENAME_VIEW_DATA, arrayView));
consumer.registerClient(EmaFactory.createReqMsg().serviceName("ELEKTRON_DD").payload(batchView), appClient);
Thank you, it worked!
BTW, what does `1` mean in batchView.add(EmaFactory.createElementEntry().uintValue(EmaRdm.ENAME_VIEW_TYPE, 1)); ?
The ViewType specifies content type of ViewData array. '1' means list of Field ID and '2' means list of Element Name.
In this case and other View for MarketPrice domain items, the View array needs to be list of Field ID, so the ViewType always is '1'.
Below is the related information in the EMA RDM Usage Guide document provided in the EMAJ package.
skajiwara avatar image skajiwara veerapath.rungruengrayubkul
Got it, thank you!
@veerapath.rungruengrayubkul ; I would like to use viewType of 2 and it is not working. Basically, I want to request data via standard field names like "ASK", "BID", etc. My domain is "MarketPrice Domain".
Any idea why it is returning all the fields instead? viewType of 1 works when I int fields (22, 25).
Regards,
josa
