The issue is not reproducable, occuring intermittently. The program gets halted and requires restart of full application.
Getting below Exception:
2017-06-07T11:58:10.217+05:30 [APP/0] [ERR] Exception in thread "pool-2-thread-1" java.lang.NullPointerException 2017-06-07T11:58:10.218+05:30 [APP/0] [ERR] at com.thomsonreuters.ema.access.SingleItem.remove(Unknown Source) 2017-06-07T11:58:10.218+05:30 [APP/0] [ERR] at com.thomsonreuters.ema.access.ItemCallbackClient.defaultMsgCallback(Unknown Source) 2017-06-07T11:58:10.218+05:30 [APP/0] [ERR] at com.thomsonreuters.ema.access.ItemCallbackClient.processRefreshMsg(Unknown Source) 2017-06-07T11:58:10.218+05:30 [APP/0] [ERR] at com.thomsonreuters.upa.valueadd.reactor.Reactor.sendDefaultMsgCallback(Reactor.java:808) 2017-06-07T11:58:10.218+05:30 [APP/0] [ERR] at com.thomsonreuters.upa.valueadd.reactor.Reactor.sendAndHandleDefaultMsgCallback(Reactor.java:823) 2017-06-07T11:58:10.219+05:30 [APP/0] [ERR] at com.thomsonreuters.upa.valueadd.reactor.WlItemHandler.callbackUser(WlItemHandler.java:2663) 2017-06-07T11:58:10.219+05:30 [APP/0] [ERR] at com.thomsonreuters.upa.valueadd.reactor.WlItemHandler.readMsg(WlItemHandler.java:1704) 2017-06-07T11:58:10.219+05:30 [APP/0] [ERR] at com.thomsonreuters.upa.valueadd.reactor.WlItemHandler.readRefreshMsg(WlItemHandler.java:1950) 2017-06-07T11:58:10.219+05:30 [APP/0] [ERR] at com.thomsonreuters.upa.valueadd.reactor.Watchlist.readMsg(Watchlist.java:277) 2017-06-07T11:58:10.219+05:30 [APP/0] [ERR] at com.thomsonreuters.upa.valueadd.reactor.Reactor.dispatchAll(Reactor.java:3217) 2017-06-07T11:58:10.219+05:30 [APP/0] [ERR] at com.thomsonreuters.upa.valueadd.reactor.Reactor.performChannelRead(Reactor.java:1750) 2017-06-07T11:58:10.220+05:30 [APP/0] [ERR] at com.thomsonreuters.ema.access.OmmBaseImpl.rsslReactorDispatchLoop(Unknown Source) 2017-06-07T11:58:10.220+05:30 [APP/0] [ERR] at com.thomsonreuters.ema.access.OmmBaseImpl.run(Unknown Source) 2017-06-07T11:58:10.220+05:30 [APP/0] [ERR] at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) 2017-06-07T11:58:10.220+05:30 [APP/0] [ERR] at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) 2017-06-07T11:58:10.220+05:30 [APP/0] [ERR] at java.lang.Thread.run(Thread.java:748)
Any leads on this?
Also the exchange rate we are fetching from EMA gives pricision upti 4 decimal places only. The same we get from RFA with higher rate of precision, Any suggestion how can we increase the precison using EMA, since our calculations are getting impacted.
