EMA change suggestions
I failed to locate a JIRA or a roadmap for EMAJ, so any plans to enhance ETA/EMA with below mentioned changes ?
1) JMX exposure of objects within the API (like RFA but in greater details).
2) A plugable config provider so all configuration can be done programatically rather than being forced to use EMAConfig.xml
3) Addition of specific payload classes to ease the packing/unpacking of the generic containers.
4) Split ETA & EMA sources into modules to separate API, examples and tools while utilizing a dependency aware modular build system (like maven) to make dependencies to other open source libs more explicit.
11.5k 16 7 10
Hi @John.Westi
We have created the case 05106233 for your EMA Java API enhancement request.
Hi @John.Westi
Elektron-SDK has updated to use Gradle and has been published to maven central.
https://search.maven.org/#search%7Cga%7C1%7Cthomsonreuters
Programmatic configuration has been made available in the ESDK 1.2.1.L1 release.
11.5k 16 7 10
Hello @John.Westi
The development team confirms that the RTSDK has delivered other solutions requested. The team does not intend to do this #1 and #3 requests unless there is additional demand.
Please check the latest version of RTSDK on GitHub page.
