Elektron example 421_marketPrice_programmaticConfig
about DictionanyType
FileDictionary (0): The EMA loads the dictionaries from the files specified in the parameters RdmFieldDictionaryFileName and EnumTypeDefFileName. ChannelDictionary (1): The EMA downloads dictionaries by requesting the dictionaries from the upstream provider.
This is from the Manual, Now look at the code:
innerMap.addKeyAscii( "Dictionary_1", MapEntry::AddEnum, ElementList() .addEnum( "DictionaryType", 1 ) .addAscii( "RdmFieldDictionaryFileName", "./RDMFieldDictionary" ) .addAscii( "EnumTypeDefFileName", "./enumtype.def" ).complete() ).complete();
The question: you specify type 1 here, which mean use ChannelDictionary, why do you need provide RdmFieldDictionaryFileName and EnumTypeDefFileName;
eikonelektronrefinitiv-realtimeelektron-sdkrrtema-apielektron-message-api
Hi James, This looks more like an Elektron question rather than App Studio. You'll probably get a quicker answer in that forum. You can move it from the cog, top right.
11.3k 25 8 13
You are correct. There is no need to provide RdmFieldDictionaryFileName and EnumTypeDefFileName when the DictionaryType is 1 (ChannelDictionary). If the file name configurations are provided while DictionaryType is ChannelDictionary, EMA will just ignore the file names.
I believe that developer just want to demonstrate how these configurations are programmatically specified.
Thanks, I am clear now.
