Error when connecting to TREP​
When initializing the channel following error occurs:
Can anyone tell what is the reason for this? Is this because the TREP sends some data which is not in RWF or has this anything to do with the InterfaceName configuration given in Universal Channel Parameters?
elektronrefinitiv-realtimeelektron-sdktreprrtema-apielektron-message-api
11.3k 25 8 13
The error message implies that EMA is able to connect to the server and then sends mount request. However, there is no valid message acknowledged to the request. It is possible that the application connects to the port that doesn't support RSSL connection (i.e. port 8101 of the SSL connection). The default port of RSSL connection is 14002. The EMA application should connect to TREP on port 14002.
