Hi Team,
We recently migrated our code using TREP EMA API using jdk 1.8. After that we faced 2 times below ConcurrentModificationException error in PROD env and hence our process terminated. Then we had to start our service again. Kindly help to fix this issue ASAP.
We made the connection to TREP using DACSID provided by MDS team and reference code EMA Consumer - Requesting and displaying MarketPrice data shared by Umer Nalla/Team.
FYI. My prev question: https://community.developers.refinitiv.com/questions/10437/socket-programming-to-trep.html?childToView=11899
java.util.ConcurrentModificationException
at java.util.HashMap$HashIterator.remove(HashMap.java:1451)
at com.thomsonreuters.ema.access.OmmBaseImpl.rsslReactorDispatchLoop(OmmBaseImpl.java:985)
at com.thomsonreuters.ema.access.OmmBaseImpl.uninitialize(OmmBaseImpl.java:258)
at com.thomsonreuters.ema.access.OmmConsumerImpl.uninitialize(OmmConsumerImpl.java:46)
at com.d3k.reuters.DealLocator.startDealService(DealLocator.java:193)
at com.d3k.reuters.DealLocator.<init>(DealLocator.java:75)
at com.d3k.reuters.ReutersStartup.startService(ReutersStartup.java:66)
at com.d3k.reuters.ReutersStartup.main(ReutersStartup.java:81)
