RDP API and I would like to use it through Postman.
I am using the RDP API and I would like to use it through Postman. How can I import the spec files for the open API for all of RDP? If I go to a specific endpoint in the playground, select Swagger I can download the individual schematics. In the past, I recall there was a way to get the spec files for all of RDP.
endpoint
23k 22 9 14
Hello @maryrose.zapanta ,
To get started exploring RDP API requests from Postman, you will need to setup clientID, following Quickstart guide for Refinitiv Data Platform will take you through obtaining it.
Next you could:
1. Download RDP Postman Starter Collection and Tutorial Samples starter collection:
2. Import the collection and the starter environment supplied with it into your Postman
3. Enrich starter environment, with your valid User, Password and Client ID
4. Run Authentication -> Get Token
5. Next you can run any RDP API request that your RDP user supplied is permissioned for.
If you are new to Postman, it may be beneficial to review some of the RDP Postman Tutorials starting with Authorization.
