How can I use C# APIs to convert SEDOLs into RICs?
I'm using the Refinitiv Data Platform (RDP) API and wondered how I could convert SEDOLs into RICs. I know that it's possible in Python with that API (e.g.: in CodeBook with the code below), but I want to get the same results in C#. Is that possible? If so: what endpoint should I use?
import refinitiv.dataplatform as rdp
rdp.open_desktop_session('DEFAULT_CODE_BOOK_APP_KEY')
rdp.convert_symbols(
    symbols = ['0216238'],
    from_symbol_type = rdp.SymbolTypes.SEDOL
rdp-apic#symbologyendpoint
1.4k 6 2 2
Hi @danieluphromes ,
The RDP library uses ‘https://api.refinitiv.com/discovery/search/v1/lookup’ and not the Symbology endpoint.
This is the request message it uses:
"View": "SearchAll",
"Terms": "0216238",
"Scope": "SEDOL",
"Select": "RIC",
"Filter": "AssetState eq \'AC\'"
Response:
  "Matches": {
    "0216238": {
      "RIC": "AV.L"
