EMA overriding all the application logging
Our application uses slf4j-log4j for logging. Since integrating EMA, all application logging is muted, only EMA logging is output. How can I have EMA not overriding all the application logging configuration.
I have seen https://community.developers.refinitiv.com/questions/6535/how-to-configure-ema-java-to-use-log4j-as-the-unde.html, and this exactly how we are configured.
ema-apiscreeninglogging
11.5k 16 7 10
Hello @andre.malenfant
I am not the SLF4J or Log4J expert but I hope this How to integrate Enterprise Message API Java with Log4j Logging Framework using Maven article might help you.
Thanks, but I have the opposite problem. Only EMA logging gets out.
11.5k 16 7 10
Could you please share your Log4j configuration file and snippet code?
