Is it possible to configure Logger in EMA to append to the existing file?
We are using Elektron Message API C++ edition and have configured the EmaConfig.xml to log into a file. But the problem is that every time we run our consumer program a new log file is created post-fixed with ProcessId. Is it possible to configure the logger to not to create a new file every time and append to the existing one instead, otherwise we have to have a scheduled task to remove all unwanted log files periodically.
Thanks.
elektronrefinitiv-realtimeelektron-sdkrrtema-apielektron-message-apilogging
4.4k 10 6 9
Hi @mojtaba.danai
Elektron Message API always create a new log file, unfortunately.
There is no configuration that can change this behavior. You have to modify OmmLoggerClient.cpp and recompile the EMA if you want to change this behavior.
