Hi @andrew.hoeing1 ,
I presume you are asking about the DSS C# SDK. Yes, when an instrument identifier list is created, the last boolean parameter allows you to define if user preferences are to be used or not.
Signature:
public static InstrumentIdentifierList Create(DssCollection<InstrumentIdentifier> instrumentIdentifiers, InstrumentValidationOptions validationOptions, bool useUserPreferencesForValidationOptions);
Use (setting it to false and using specified validation rule):
IdentifierList = InstrumentIdentifierList.Create( new[] { new InstrumentIdentifier { Identifier = "191216100", IdentifierType = IdentifierType.Cusip }, new InstrumentIdentifier { Identifier = "2005973", IdentifierType = IdentifierType.Sedol }, new InstrumentIdentifier { Identifier = "AAPL.OQ", IdentifierType = IdentifierType.Ric } }, new InstrumentValidationOptions { UseExchangeCodeInsteadOfLipper = true, AllowHistoricalInstruments = false, AllowOpenAccessInstruments = false, ExcludeFinrAsPricingSourceForBonds = false, UseConsolidatedQuoteSourceForCanada = false, UseConsolidatedQuoteSourceForUsa = false, UseUsQuoteInsteadOfCanadian = true }, false);
