Today I observe perpetual
HTTP request failed: EikonError-Backend error. 500 Internal Server Error
and
HTTP request failed: EikonError-UDF Core request failed. Gateway Time-out
errors. No updates of the code or scope of RICs from my side. Same code used to work up to today morning.
Example:
(Pdb) p ek.__version__ '1.1.10' (Pdb) p params {'start_date': datetime.datetime(2021, 11, 23, 18, 10, tzinfo=<DstTzInfo 'Europe/Moscow' MSK+3:00:00 STD>), 'end_date': datetime.datetime(2021, 11, 23, 18, 40, tzinfo=<DstTzInfo 'Europe/Moscow' MSK+3:00:00 STD>), 'interval': 'minute', 'count': 1, 'calendar': 'tradingdays', 'corax': 'adjusted', 'normalize': True} (Pdb) p sys.version '3.8.8 (tags/v3.8.8:024d805, Feb 19 2021, 13:18:16) [MSC v.1928 64 bit (AMD64)]' (Pdb) ek.get_timeseries(["TSLA.O"], ["CLOSE"], **params) 2021-11-24 09:56:30,874 pyeikon DEBUG Request:{'Entity': {'E': 'TimeSeries', 'W': {'rics': ['TSLA.O'], 'fields': ['CLOSE', 'TIMESTAMP'], 'interval': 'minute', 'startdate': '2021-11-23T18:10:00+03:00', 'enddate': '2021-11-23T18:40:00+03:00', 'count': 1, 'calendar': 'tradingdays', 'corax': 'adjusted'}}} 2021-11-24 09:56:30,876 pyeikon DEBUG Request to http://127.0.0.1:9060/api/v1/data headers = {'Content-Type': 'application/json', 'x-tr-applicationid': '***', 'Authorization': 'Bearer ***'} params = None 2021-11-24 09:56:30,881 httpx._client DEBUG HTTP Request: POST http://127.0.0.1:9060/api/v1/data "HTTP/1.1 307 Temporary Redirect" 2021-11-24 09:56:31,095 httpx._client DEBUG HTTP Request: POST http://127.0.0.1:9060/api/udf "HTTP/1.1 200 OK" 2021-11-24 09:56:31,097 pyeikon DEBUG HTTP Response code: 200 2021-11-24 09:56:31,104 pyeikon DEBUG HTTP Response: {"ErrorCode":500,"ErrorMessage":"Backend error. 500 Internal Server Error"} 2021-11-24 09:56:31,106 pyeikon ERROR Backend error. 500 Internal Server Error 2021-11-24 09:56:31,108 pyeikon ERROR HTTP request failed: EikonError-Backend error. 500 Internal Server Error *** eikon.eikonError.EikonError: Error code 500 | Backend error. 500 Internal Server Error
I have try/catch retries for errors like that, so I observe the following stream of alternating errors:
2021-11-24 09:53:51,059 root ERROR Error code 2504 | UDF Core request failed. Gateway Time-out 2021-11-24 09:54:01,393 pyeikon ERROR Backend error. 500 Internal Server Error 2021-11-24 09:54:01,393 pyeikon ERROR HTTP request failed: EikonError-Backend error. 500 Internal Server Error 2021-11-24 09:54:01,394 root ERROR Error code 500 | Backend error. 500 Internal Server Error 2021-11-24 09:54:11,739 pyeikon ERROR Backend error. 500 Internal Server Error 2021-11-24 09:54:11,739 pyeikon ERROR HTTP request failed: EikonError-Backend error. 500 Internal Server Error 2021-11-24 09:54:11,741 root ERROR Error code 500 | Backend error. 500 Internal Server Error 2021-11-24 09:54:22,060 pyeikon ERROR Backend error. 500 Internal Server Error 2021-11-24 09:54:22,061 pyeikon ERROR HTTP request failed: EikonError-Backend error. 500 Internal Server Error 2021-11-24 09:54:22,064 root ERROR Error code 500 | Backend error. 500 Internal Server Error 2021-11-24 09:54:51,598 pyeikon ERROR UDF Core request failed. Gateway Time-out 2021-11-24 09:54:51,598 pyeikon ERROR HTTP request failed: EikonError-UDF Core request failed. Gateway Time-out 2021-11-24 09:54:51,599 root ERROR Error code 2504 | UDF Core request failed. Gateway Time-out 2021-11-24 09:55:20,847 pyeikon ERROR UDF Core request failed. Gateway Time-out 2021-11-24 09:55:20,848 pyeikon ERROR HTTP request failed: EikonError-UDF Core request failed. Gateway Time-out 2021-11-24 09:55:20,851 root ERROR Error code 2504 | UDF Core request failed. Gateway Time-out 2021-11-24 09:55:31,193 pyeikon ERROR Backend error. 500 Internal Server Error 2021-11-24 09:55:31,194 pyeikon ERROR HTTP request failed: EikonError-Backend error. 500 Internal Server Error 2021-11-24 09:55:31,197 root ERROR Error code 500 | Backend error. 500 Internal Server Error 2021-11-24 09:55:41,550 pyeikon ERROR Backend error. 500 Internal Server Error 2021-11-24 09:55:41,550 pyeikon ERROR HTTP request failed: EikonError-Backend error. 500 Internal Server Error 2021-11-24 09:55:41,552 root ERROR Error code 500 | Backend error. 500 Internal Server Error 2021-11-24 09:55:51,916 pyeikon ERROR Backend error. 500 Internal Server Error 2021-11-24 09:55:51,916 pyeikon ERROR HTTP request failed: EikonError-Backend error. 500 Internal Server Error 2021-11-24 09:55:51,918 root ERROR Error code 500 | Backend error. 500 Internal Server Error 2021-11-24 09:56:02,267 pyeikon ERROR Backend error. 500 Internal Server Error 2021-11-24 09:56:02,267 pyeikon ERROR HTTP request failed: EikonError-Backend error. 500 Internal Server Error 2021-11-24 09:56:02,270 root ERROR Error code 500 | Backend error. 500 Internal Server Error 2021-11-24 09:56:31,490 pyeikon ERROR UDF Core request failed. Gateway Time-out 2021-11-24 09:56:31,490 pyeikon ERROR HTTP request failed: EikonError-UDF Core request failed. Gateway Time-out 2021-11-24 09:56:31,493 root ERROR Error code 2504 | UDF Core request failed. Gateway Time-out 2021-11-24 09:56:41,826 pyeikon ERROR Backend error. 500 Internal Server Error 2021-11-24 09:56:41,827 pyeikon ERROR HTTP request failed: EikonError-Backend error. 500 Internal Server Error 2021-11-24 09:56:41,829 root ERROR Error code 500 | Backend error. 500 Internal Server Error 2021-11-24 09:57:11,036 pyeikon ERROR UDF Core request failed. Gateway Time-out 2021-11-24 09:57:11,037 pyeikon ERROR HTTP request failed: EikonError-UDF Core request failed. Gateway Time-out
