Cannot access CBA.AX minute data
Hi team,
tmp = ek.get_timeseries(["MSFT.O"], fields = 'CLOSE', start_date="2021-10-28 09:00:00", end_date="2021-10-28 10:00:00", interval='minute')
# This code work for me
tmp2 = ek.get_timeseries(["CBA.AX"], fields = 'CLOSE', start_date="2021-10-28 09:00:00", end_date="2021-10-28 09:05:00", interval='minute')
# CBA.AX will report "No data available error", not sure why, can you let me know? Thank you!
FYI In excel, I can get 30min level CBA.AX data
=@RHistory($A$2,".Timestamp;.Close;.Close","INTERVAL:30M",,"TSREPEAT:NO CH:Fd",I18)
eikon-data-apiequitiespython apiprice-history
1.7k 2 4 7
Hi @yu.yang ,
As checked, there're no CLOSE data of CBA.AX available at the start-end date range in your code (and there's no start-end date range specified in your Excel formula so the data is returned there)
I tried adjust the date parameters to be wider and the data are returned properly (without the data between start_date="2021-10-28 09:00:00", end_date="2021-10-28 09:05:00)
regarding this thread, get_timeseries method of Eikon Data APIs library always returns timestamps in GMT.
I checked in Eikon Excel and no data is returned during this date time range too (I did compare the result between the API and Excel so I belive that Eikon Excel timezone is the local timezone, which is GMT+7 for me)
