Hello @Henri.GARDON
If I understand the question correctly, jDacsLib.jar is part of Open DACS, and if you are integrating with RFAJ 8.2, and looking to integrate with OpenDACS, download Open DACS SDK 8.2 Java from Open Data Access Control System Java Downloads. It will require dev portal login (registration) and if you are not currently a member of API family - request and approval for the download.
If I am missing the question- let me know.
We are looking for the opendacs library version packaged into rfaj8.2.0.L2 library and where is it located into the .jar ?
Thanks,
Henri
Hello @Henri.GARDON ,
General DACS access is included with RFA, it is part of rfa.jar, so is of the same version as the version of RFA.
Open DACS is not included with RFA, it is a separate API/installation Open Data Access Control System API - Java
Hello @zoya faberov ,
Thank you for your prompt answer.
Is this Open Data Access Control System API which is linked to the below yellow library ?
Thanks,
DACS integration functionality that is part of RFA and is different and is intended to work with DACS locks, parse and understand, or create, see JRFA Dacs Lock Developer Guide to learn more. For example, we may require to create and include DACS locks if working on a custom publisher application.
Open DACS API is intended to address questions on entitlements, manage data access, including on behalf of, report data access, ensure exchange compliant data access at all times. To learn more see Open Data Access Control System API - Java, article An Introduction to the DACS Entitlement System for OpenDACS Developers may also be helpful
