I notice that sometime my Open DACS application receive event type 2 after the user call logout. From the dacsSubscribeClient example, it seems to check only event type RFA_DACS_PACKAGE.
In which case does DACS send the event type 2?
I did some research and found that the event type 2 is RFA Completion Event and the Open DACS application will receive completion event if it set the completion event flag to true when calling AuthorizationSystem::createAuthorizationAgent. The dacsSubscribeClient set it to true by default.
However with initial test using the example, it seems like I did not get completion event. This is because the example does not keep dispatching after calling logout. I have changed the example to call waitForCallbackEvent as below and I can get event type 2 as my application.
// Log out. pClient->logout(); pClient->waitForCallbackEvent(waitTime);
And then add codes to check completion event in processEvent method
void DacsSubscribeClient::processEvent(const Event &event) { … if(eventType == rfa::common::ComplEventEnum) { std::cout<<"****** Receive Completion Event"<<std::endl; } … }
dacsSubscribeClient example shows dacs event handling. OpenDacs uses RFA libraries, which are grouped into packages. RFA_PACKAGE_2 events are RFASessionLayer events described in RFA include SessionLayerEnums.h
